    Search module for livecam / stream
    28 Posts 4 Posters 5.1k Views 4 Watching
      c1olli
      You have a mistake in the config file.
      I think the bracket in line 950 is wrong .
      • JerryPJ
        JerryP @KamiSchami
        @KamiSchami
        Yes you must first install the module.
        https://github.com/shbatm/MMM-RTSPStream
        pleas follow the wiki.
        and the line 950 is wrong.
        you must end whit
        } ] at line 950
        • KamiSchamiK
          KamiSchami
          … no, sorry 🙈 omxplayer is installed
          Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
          • KamiSchamiK
            KamiSchami
            … oooooh… cool, but no pic
            JerryPJ 1 Reply Last reply Reply Quote 0
            • KamiSchamiK
              KamiSchami
              Yes, yes ,yes HERO od my day !!! Thank you!
              • JerryPJ
                JerryP @KamiSchami
                • JerryPJ
                  JerryP @KamiSchami
                  @KamiSchami I think you have made a small config failler.
                  But I sa a later post that i’t was up and running.
                  Picture please.
                  • KamiSchamiK
                    KamiSchami
                    works. Still have to adjust the size a bit. Unfortunately it currently fades my buttons. Any other tip for formatting the css for me?
                    JerryPJ 2 Replies Last reply Reply Quote 0
                    • JerryPJ
                      JerryP @KamiSchami
                      @KamiSchami
                      And if you put in the config
                      	URL"http://"bla bla bla
                              width: 590,
                      	height: 332
                      • JerryPJ
                        JerryP @KamiSchami
                        @KamiSchami
                        When you put this in the CSS the white outline (Box) is going to none
                        * custom.css
                        .MMM-RTSPStream .innerWrapper {
                            border-style: none;
                        • KamiSchamiK
                          KamiSchami
                          Ok great 🍻
                          • KamiSchamiK
                            KamiSchami
                            ok, the edge is gone, but i can’t get the cam behind my button 🙈
                            • JerryPJ
                              JerryP @KamiSchami
                              @KamiSchami
                              can you pleas ad your config file.
                              • KamiSchamiK
                                KamiSchami
                                All? It’s long 🤣
                                • JerryPJ
                                  JerryP @KamiSchami
                                  @KamiSchami only the part of the
                                  module: ‘MMM-RTSPStream’
                                  • KamiSchamiK
                                    KamiSchami
                                    • JerryPJ
                                      JerryP @KamiSchami
                                      @KamiSchami You can use this.
                                      		module: "MMM-RTSPStream",
                                      		disabled: false, //false, true
                                      		position: "middle",
                                      			autoStart: true,
                                      			rotateStreams: false,
                                      			rotateStreamTimeout: 20,
                                      			moduleWidth: 468,
                                      			moduleHeight: 320,
                                      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                                      			remotePlayer: 'none',
                                      			showSnapWhenPaused: false,
                                      			remoteSnaps: false,
                                      			  stream1: {
                                      			  url: 'https://cam01.binz-kabel.de/cam1.m3u8',
                                      			  protocol: "tcp",
                                      			  frameRate: 25,
                                      			  muted: true,
        hwAccel: true,
        width: 450,
        height: 300,
                                      • JerryPJ
                                        JerryP @JerryP
                                        @KamiSchami this part I meen
                                        			  stream1: {
                                        			  protocol: "tcp",
                                        			  frameRate: 25,
                                        			  muted: true,
        hwAccel: true,
        width: 450,
        height: 300,
                                        • KamiSchamiK
                                          KamiSchami
                                          Thanks, it was late yesterday. The camera was gray and night mode and my buttons are also gray, I have to check if it is brighter.
                                          • KamiSchamiK
                                            KamiSchami
                                            hi, it’s still over the button when i enlarge the module 🙈
