    Search module for livecam / stream
    28 Posts 4 Posters 5.3k Views 4 Watching
    • JerryPJ
      JerryP @KamiSchami
      @KamiSchami
      And if you put in the config
      	URL"http://"bla bla bla
              width: 590,
      	height: 332
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @KamiSchami
        @KamiSchami
        When you put this in the CSS the white outline (Box) is going to none
        * custom.css
        .MMM-RTSPStream .innerWrapper {
            border-style: none;
        • KamiSchamiK
          KamiSchami
          Ok great 🍻
          Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
          • KamiSchamiK
            KamiSchami
            ok, the edge is gone, but i can’t get the cam behind my button 🙈
            • JerryPJ
              JerryP @KamiSchami
              @KamiSchami
              can you pleas ad your config file.
              • KamiSchamiK
                KamiSchami
                All? It’s long 🤣
                • JerryPJ
                  JerryP @KamiSchami
                  @KamiSchami only the part of the
                  module: ‘MMM-RTSPStream’
                  • KamiSchamiK
                    KamiSchami
                    • JerryPJ
                      JerryP @KamiSchami
                      @KamiSchami You can use this.
                      		module: "MMM-RTSPStream",
                      		disabled: false, //false, true
                      		position: "middle",
                      			autoStart: true,
                      			rotateStreams: false,
                      			rotateStreamTimeout: 20,
                      			moduleWidth: 468,
                      			moduleHeight: 320,
                      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                      			remotePlayer: 'none',
                      			showSnapWhenPaused: false,
                      			remoteSnaps: false,
                      			  stream1: {
                      			  url: 'https://cam01.binz-kabel.de/cam1.m3u8',
                      			  protocol: "tcp",
                      			  frameRate: 25,
                      			  muted: true,
                                                hwAccel: true,
                                                width: 450,
                                                height: 300,
                      • JerryPJ
                        JerryP @JerryP
                        @KamiSchami this part I meen
                        			  stream1: {
                        			  protocol: "tcp",
                        			  frameRate: 25,
                        			  muted: true,
                                                  hwAccel: true,
                                                  width: 450,
                                                  height: 300,
                        • KamiSchamiK
                          KamiSchami
                          Thanks, it was late yesterday. The camera was gray and night mode and my buttons are also gray, I have to check if it is brighter.
                          • KamiSchamiK
                            KamiSchami
                            hi, it’s still over the button when i enlarge the module 🙈
                            D 1 Reply Last reply
                              drx1984 @KamiSchami
                              @KamiSchami what am I doing wrong?
                              for me MM starts but the whole screen remains black
                              Can someone help me please?
                              Is the MMM-RTSPStream module up to date? still works?
                              • JerryPJ
                                JerryP
                                @drx1984
                                This one is working fine.
                                De URL was wrong.
                                position: "middle",
                                	autoStart: true,
                                	moduleWidth: 468,
                                	moduleHeight: 320,
                                	remoteSnaps: false,
                                	stream1: {
                                	url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                                			  protocol: "tcp",
                                			  frameRate: 25,
                                			  muted: true,
                                                          hwAccel: true,
                                                          width:  450,
                                                          height: 300,
                                  drx1984 @JerryP
                                  @JerryP unfortunately it still doesn’t work.
                                  Magic mirror starts but it just remains black and the terminal says that the module is not available?
                                  I have already copied the module into the modules folder with the command “git clone”.
                                  • JerryPJ
                                    JerryP @drx1984
                                    @drx1984
                                    Goodmorning,
                                    I think the module is not install correctly
                                    have you follow the instructions https://github.com/shbatm/MMM-RTSPStream
                                    You can also
                                    go into terminal.
                                    cd ~/MagicMirror/modules/MMM-RTSPStream
                                    git pull
                                    npm install
                                    If that i’s not working I can only suggest that you delete your current installation of the module and re-install it.
