    Search module for livecam / stream
    28 Posts 4 Posters 5.3k Views 4 Watching
    • JerryPJ
      JerryP @KamiSchami
      @KamiSchami only the part of the
      module: ‘MMM-RTSPStream’
      • KamiSchamiK
        KamiSchami
        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
        JerryPJ 1 Reply Last reply
        • JerryPJ
          JerryP @KamiSchami
          @KamiSchami You can use this.
          		module: "MMM-RTSPStream",
          		disabled: false, //false, true
          		position: "middle",
          			autoStart: true,
          			rotateStreams: false,
          			rotateStreamTimeout: 20,
          			moduleWidth: 468,
          			moduleHeight: 320,
          			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
          			remotePlayer: 'none',
          			showSnapWhenPaused: false,
          			remoteSnaps: false,
          			  stream1: {
          			  url: 'https://cam01.binz-kabel.de/cam1.m3u8',
          			  protocol: "tcp",
          			  frameRate: 25,
          			  muted: true,
                                    hwAccel: true,
                                    width: 450,
                                    height: 300,
          • JerryPJ
            JerryP @JerryP
            @KamiSchami this part I meen
            			  stream1: {
            			  protocol: "tcp",
            			  frameRate: 25,
            			  muted: true,
                                      hwAccel: true,
                                      width: 450,
                                      height: 300,
            • KamiSchamiK
              KamiSchami
              Thanks, it was late yesterday. The camera was gray and night mode and my buttons are also gray, I have to check if it is brighter.
              • KamiSchamiK
                KamiSchami
                hi, it’s still over the button when i enlarge the module 🙈
                D 1 Reply Last reply
                  drx1984 @KamiSchami
                  @KamiSchami what am I doing wrong?
                  for me MM starts but the whole screen remains black
                  Can someone help me please?
                  Is the MMM-RTSPStream module up to date? still works?
                  • JerryPJ
                    JerryP
                    @drx1984
                    This one is working fine.
                    De URL was wrong.
                    position: "middle",
                    	autoStart: true,
                    	moduleWidth: 468,
                    	moduleHeight: 320,
                    	remoteSnaps: false,
                    	stream1: {
                    	url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                    			  protocol: "tcp",
                    			  frameRate: 25,
                    			  muted: true,
                                              hwAccel: true,
                                              width:  450,
                                              height: 300,
                      drx1984 @JerryP
                      @JerryP unfortunately it still doesn’t work.
                      Magic mirror starts but it just remains black and the terminal says that the module is not available?
                      I have already copied the module into the modules folder with the command “git clone”.
                      • JerryPJ
                        JerryP @drx1984
                        @drx1984
                        Goodmorning,
                        I think the module is not install correctly
                        have you follow the instructions https://github.com/shbatm/MMM-RTSPStream
                        You can also
                        go into terminal.
                        cd ~/MagicMirror/modules/MMM-RTSPStream
                        git pull
                        npm install
                        If that i’s not working I can only suggest that you delete your current installation of the module and re-install it.
