    Default Calendar doesn't show annually events
    12 Posts 4 Posters 2.6k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @ghelweg
      @ghelweg My default calendar shows birthdays very well. Also, the issue in the referred thread did not seem to be a general issue since Sam was not able to reproduce it.
      Are you sure it is a module issue and not one of your (google) calendar?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G Offline
        ghelweg @lavolp3
        @lavolp3 Hi! I don’t really know. I 've tested with two different (microsoft)-calendars and both don’t show the yearly events, and I can reproduce that. I am also running the MagicMirror in a VM for testing things, but on both, the hardware and the vm, the same problem.
        I also tested the same calendar with a 3party-module. However, there is no problem.
        Thanks!
        • G Offline
          ghelweg
          Hi there!
          Looks like that this is a problem with (my) microsoft-calendar. I tested with a google-calendar and everything worked fine.
          Maybe there is someone, who can reproduce that, too and has a solution?
          Thanks a lot!
            sdetweil @ghelweg
            @ghelweg what mm version are u on? lots of Microsoft cal related fixes in 2.14
            • G Offline
              ghelweg @sdetweil
              @sdetweil Hi there! The version is 2.14.0.
                sdetweil @ghelweg
                @ghelweg if u download the ics file u can edit it just text. but I’d be interested in seeing a couple events
                  @ghelweg can’t post it here u can send to my email. same userid as here on gmail
                  • T Offline
                    Twisticles @sdetweil
                    @sdetweil I’m completely new to MM (as of yesterday) and encountering the same thing with outlook ics. Recurring weekly/monthly events show up fine, but annual events don’t!
                    Running MM v2.14.0
                    What can I provide to help troubleshoot this? (Might have to point me in the right direction of how to post code).
                      sdetweil @Twisticles
                      @twisticles if u can, send the ics file to my email so I can test w it.
                      second u can turn on debug by changing a line in config.js
                      it will produce a lot of messages.
                      	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                      then start mm like this
                      npm start > somefile
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        @sdetweil Thanks! I will do.
