    Default Calendar doesn't show annually events
    12 Posts 4 Posters 2.6k Views 4 Watching
    • G Offline
      ghelweg
      Re: Default Calendar Module will not display an annually/monthly recurring event at end of March.
      Hi there!
      I know, this topic is quite old. But the same problem for me. Has there been a solution for this problem? I’m using the default calendar module and it will not show yearly events. If I change the events to “weekly” everything is ok. But I want to show birthdays and so I will need the yearly events :-)
      Is there someone who can help?
      Thank you!
      • lavolp3L Offline
        lavolp3 Module Developer @ghelweg
        @ghelweg My default calendar shows birthdays very well. Also, the issue in the referred thread did not seem to be a general issue since Sam was not able to reproduce it.
        Are you sure it is a module issue and not one of your (google) calendar?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • G Offline
          ghelweg @lavolp3
          @lavolp3 Hi! I don’t really know. I 've tested with two different (microsoft)-calendars and both don’t show the yearly events, and I can reproduce that. I am also running the MagicMirror in a VM for testing things, but on both, the hardware and the vm, the same problem.
          I also tested the same calendar with a 3party-module. However, there is no problem.
          Thanks!
          • G Offline
            ghelweg
            Hi there!
            Looks like that this is a problem with (my) microsoft-calendar. I tested with a google-calendar and everything worked fine.
            Maybe there is someone, who can reproduce that, too and has a solution?
            Thanks a lot!
              sdetweil @ghelweg
              @ghelweg what mm version are u on? lots of Microsoft cal related fixes in 2.14
              • G Offline
                ghelweg @sdetweil
                @sdetweil Hi there! The version is 2.14.0.
                  sdetweil @ghelweg
                  @ghelweg if u download the ics file u can edit it just text. but I’d be interested in seeing a couple events
                    @ghelweg can’t post it here u can send to my email. same userid as here on gmail
                    • T Offline
                      Twisticles @sdetweil
                      @sdetweil I’m completely new to MM (as of yesterday) and encountering the same thing with outlook ics. Recurring weekly/monthly events show up fine, but annual events don’t!
                      Running MM v2.14.0
                      What can I provide to help troubleshoot this? (Might have to point me in the right direction of how to post code).
                        sdetweil @Twisticles
                        @twisticles if u can, send the ics file to my email so I can test w it.
                        second u can turn on debug by changing a line in config.js
                        it will produce a lot of messages.
                        	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                        then start mm like this
                        npm start > somefile
                        T 2 Replies Last reply Reply Quote 0
