Default Calendar doesn't show annually events
@ghelweg My default calendar shows birthdays very well. Also, the issue in the referred thread did not seem to be a general issue since Sam was not able to reproduce it.
Are you sure it is a module issue and not one of your (google) calendar? -
@lavolp3 Hi! I don’t really know. I 've tested with two different (microsoft)-calendars and both don’t show the yearly events, and I can reproduce that. I am also running the MagicMirror in a VM for testing things, but on both, the hardware and the vm, the same problem.
I also tested the same calendar with a 3party-module. However, there is no problem.
Thanks!
Hi there!
Looks like that this is a problem with (my) microsoft-calendar. I tested with a google-calendar and everything worked fine.
Maybe there is someone, who can reproduce that, too and has a solution?
Thanks a lot!
@ghelweg what mm version are u on? lots of Microsoft cal related fixes in 2.14
@sdetweil Hi there! The version is 2.14.0.
@ghelweg if u download the ics file u can edit it just text. but I’d be interested in seeing a couple events
@ghelweg can’t post it here u can send to my email. same userid as here on gmail
@sdetweil I’m completely new to MM (as of yesterday) and encountering the same thing with outlook ics. Recurring weekly/monthly events show up fine, but annual events don’t!
Running MM v2.14.0What can I provide to help troubleshoot this? (Might have to point me in the right direction of how to post code).
@twisticles if u can, send the ics file to my email so I can test w it.
second u can turn on debug by changing a line in config.js
it will produce a lot of messages.logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
then start mm like this
npm start > somefile
@sdetweil Thanks! I will do.
