    MM Docker with MMM-Todoist & MMM-Admin-Interface
    6 Posts 3 Posters 1.3k Views 3 Watching
    • I Offline
      irontamoor
      Hello All,
      i’m running MM in docker and trying to use MMM-Todoist & MMM-Admin-Interface, I’ve done git clone and npm install in the docker but i still can not use it any one know why ?
      I also get a lot of errors ;
      Manual Install: Screenshot 2021-01-14 at 12.37.02.png
      Docker Install: Screenshot 2021-01-14 at 12.41.06.png
        ashishtank Module Developer @irontamoor
        @irontamoor The error suggests that instead of .css or .js file it is responding with html (could be 404 or other error details). Go to network tab and filter with mmm-todo and check the response from server.
        Did you do npm install for this modules in docker ? I think you need that for external modules in docker.
        • karsten13K Offline
          karsten13
          tested this (in severonly mode, not on a pi) with MMM-Todoist and it works.
          We need more info about your setup:
          • which hardware? Pi, Linux VM?
          • which docker image?
          • how did you start the image?
          • how did you install the module(s)? Did you the installation from within the running container?
          • MagicMirror version?
          • I Offline
            irontamoor @ashishtank
            @ashishtank said in MM Docker with MMM-Todoist & MMM-Admin-Interface:
            @ashishtank thank you for responding, I did the following; docker exec magic_mirror /bin/sh
            cd to modules (Todoist) npm install (like it says to)
            Is this correct? Or do I have to do it out of docker?
            • I Offline
              irontamoor @karsten13
              @karsten13
              Thank you for responding,
              VM I used ubuntu server 20.0.4 and rancher os
              which docker image?
              bastilimbach/docker-magicmirror
              Docker start magic_mirror
              Outside of docker using git clone
              Latest docker image
              https://github.com/bastilimbach/docker-magicmirror
              • I Offline
                irontamoor
                fixed by accident i put it under magic mirror > modules > default, moved it under magic mirror > modules now works
