Local .ics file access error
7 Posts 3 Posters 1.1k Views 3 Watching
  • K Offline
    kai
    Hi there,
    I tried to access a local .ics file with the default calendar module. When I use an external URL within the calendar’s configuration there is no problem - the calendar entries are displayed on my magic mirror.
    If I download the same file and copy it into my magic mirror directory and change the calendar’s configuration to URL: "http://localhost:8080/file.ics" (or URL: "http://IP_of_MM:8080/file.ics") the calendar module does not show any entries. I tried both putting the file into the magic mirror’s root directory (like @Sean mentioned in topic 9092) and putting into a subdirectory (like @Shockwave mentioned in topic 467) but I did not succeed yet.
    When I try to access the file directly by entering the config’s URL into a browser (on another PC within the same network) I always get an error like “cannot get file.ics”; when quitting the magic mirror there are access errors / 404 errors displayed as well.
    Hence to my mind it is some kind of access / authorization error…?!?
    Any hints appreciated. Thanks a lot.
    May the code be with you
    -kai
    • L Offline
      lolo
      Should be like this .
      url: "webcal://0.0.0.0:8080/file.ics"
      • K Offline
        kai
        Thanks a lot, @lolo
        Unfortunately this does not make any difference… using webcal://... displays “no appointments” within the calendar as well. The MM’s log says “Calendar error. Could not fetch calendar … 404: Not found”.
        • L Offline
          lolo
          I have local calendar and is working fine.
          Copy file.ics in modules folder and add to config
          url: "webcal://localhost:8080/modules/file.ics"
          or
          url: "webcal://0.0.0.0:8080/modules/file.ics"
          • K Offline
            kai
            Thanks a lot @lolo - you made my day!
            That was the crucial point: the modules directory. I now can access the file via url: "webcal://[MM-IP]/modules/file.ics"! :-)
            Thanks a lot again!!!
              ashishtank Module Developer
              @kai as @lolo suggested the files will be accessible if it is in modules directory. Not all files on root level are accessible directly. Below directories and their child directories and files are accessible from browser.
              "/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"
              • K Offline
                kai
                Thank you very much @ashishtank for sharing this!
                Good to know! :-)
