Unsolved I can't get mmm-screencast to work
@JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
module: 'MMM-Screencast', position: 'bottom_right', config: { position: 'center', castName: 'Mirror', height: 300, width: 500, }},
@jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
to allow machines (phone table laptop…) to connect to the mm server running the module
@sdetweil how do I check for those?
The address and ipWhitelist are both set this way.
@jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
I’m thinking that you want something that’s not possible. Or I’m confused.
The Shield is a different device. so unplug the power of it.
Than take a phone whits is on the seem wifi network as the mirror
Then use your phone en pick a movie on YouTube.com
and hit the cast button.Your config looks oke.
The pull is als don
so I don’t know why it’s not working
In the picture you can see my 2 mirrors.
“Huiskamer”
“Spiegeltje” -
var config = { address: "0.0.0.0" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], useHttps: false, httpsPrivateKey: "", httpsCertificate: "", language: "nl", timeFormat: 24, units: "metric", modules:
This is my part of de var (ip handeling)
@sdetweil i removed the ip adres of the laptop an tv.
But for the mmm-screencast module is That no problem -
@JerryP why cant u start allowing everything, and tighten it up later.
@JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
I unplugged the shield as that is what you asked me to try.
I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
