    I can't get mmm-screencast to work
    59 Posts 6 Posters 30.8k Views 6 Watching
      jste84 @fribse
      @fribse its wifi… Is there a way to check/fix this?
      F JerryPJ 2 Replies Last reply Reply Quote 0
      • F Offline
        fribse @jste84
        @jste84 As long as the devices are on the same, ie. both on cable, or both on wifi, then you should be good.
        One thing I wonder though, the shield, is that on cable? It could be client isolation, if you have that activated on your wifi, then it won’t work.
        • JerryPJ Offline
          JerryP @jste84
          @jste84
          lets try to pull the module!!
          Navigate to the modules directory via the follow command:
          cd MagicMirror/modules/MMM-Screencast
          git pull
          npm install
          F J 2 Replies Last reply Reply Quote 0
          • F Offline
            fribse @JerryP
            @JerryP said in I can't get mmm-screencast to work:
            nam install
            Is that a new command? :-D
              sdetweil @fribse
              @fribse typo. npm
                jste84 @JerryP
                @JerryP ok so have done this. Git pull says up to date.
                Npm install - installs with 12 vulnerabilities…
                JerryPJ 1 Reply Last reply Reply Quote 0
                • JerryPJ Offline
                  JerryP @jste84
                  @jste84 OK.
                  And now when you reboot the mirror.
                  Are u using the same wifi network for our phone and mirror. to broadcast YouTube?? Frome your laptop it’s not working. “At my place only the phone and iPad can connect the module”
                    jste84 @fribse
                    @fribse Shield is WiFi too…
                      jste84 @JerryP
                      @JerryP same Wifi network for the mirror and shield.
                      Reboot and when I open YouTube… Still no luck finding the mirror
                      • JerryPJ Offline
                        JerryP @jste84
                        @jste84
                        Can you try to put de Nvidia shield down. (unplug the power) and is I’t than possible tot see the screencast on the mirror (maybe reboot the mirror after you hef unplug the Nvidia shield)
                        and kan you post one more time te config.
                          jste84 @JerryP
                          @JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
                          module: 'MMM-Screencast',
                          		position: 'bottom_right',
                          			position: 'center',
                          			castName: 'Mirror',
                          			height: 300,
                          			width: 500,
                          S JerryPJ 2 Replies Last reply Reply Quote 0
                            sdetweil @jste84
                            @jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
                            u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
                            to allow machines (phone table laptop…) to connect to the mm server running the module
                              jste84 @sdetweil
                              @sdetweil how do I check for those?
                              The address and ipWhitelist are both set this way.
                              • JerryPJ Offline
                                JerryP @jste84
                                @jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
                                I’m thinking that you want something that’s not possible. Or I’m confused.
                                The Shield is a different device. so unplug the power of it.
                                Than take a phone whits is on the seem wifi network as the mirror
                                Then use your phone en pick a movie on YouTube.com
                                and hit the cast button.
                                Your config looks oke.
                                The pull is als don
                                so I don’t know why it’s not working
                                In the picture you can see my 2 mirrors.
                                “Huiskamer”
                                “Spiegeltje”
                                • JerryPJ Offline
                                  JerryP @jste84
                                  @jste84
                                  var config = {
                                  	address: "0.0.0.0"
                                  	port: 8080,
                                  	useHttps: false,
                                  	httpsPrivateKey: "",
                                  	httpsCertificate: "",
                                  	language: "nl",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  modules:
                                  This is my part of de var (ip handeling)
                                  S J 2 Replies Last reply Reply Quote 0
                                    sdetweil @JerryP
                                    @JerryP your whitelist says only apps inside mirror can connect
                                    use
                                    ipWhitelist:[],
                                    • JerryPJ Offline
                                      JerryP @sdetweil
                                      @sdetweil i removed the ip adres of the laptop an tv.
                                      But for the mmm-screencast module is That no problem
                                        sdetweil @JerryP
                                        @JerryP why cant u start allowing everything, and tighten it up later.
                                          jste84 @JerryP
                                          @JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
                                            jste84
                                            I unplugged the shield as that is what you asked me to try.
                                            I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
                                            • 2 / 3
