    I can't get mmm-screencast to work
    59 Posts 6 Posters 34.7k Views 6 Watching
    • F
      fribse @JerryP
      @JerryP You’re right, ha ha, that’s been there for ages, it works, just places it in the middle of it all, but looks better at the bottom :-D
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @fribse
        @fribse So now whit the new line of code i’t a live.
        Lets stream YouTube.
        I use the module for the kids to see school movies. Home school. hahaha
        F 1 Reply Last reply
        • F
          fribse @JerryP
          @JerryP I wasn’t the OP, I never had a problem I just commented on how to post the code :-)
            jste84 @JerryP
            @JerryP I’ve copied your config and still can’t find the device. When I try and cast YouTube. The only device that shows is my Nvidia shield 😓
            • F
              fribse @jste84
              @jste84 Are the pi on wifi or cable? It could be due to mDNS not propagating across wired/wireless.
                jste84 @fribse
                @fribse its wifi… Is there a way to check/fix this?
                F JerryPJ 2 Replies Last reply
                • F
                  fribse @jste84
                  @jste84 As long as the devices are on the same, ie. both on cable, or both on wifi, then you should be good.
                  One thing I wonder though, the shield, is that on cable? It could be client isolation, if you have that activated on your wifi, then it won’t work.
                  • JerryPJ
                    JerryP @jste84
                    @jste84
                    lets try to pull the module!!
                    Navigate to the modules directory via the follow command:
                    cd MagicMirror/modules/MMM-Screencast
                    git pull
                    npm install
                    F J 2 Replies Last reply
                    • F
                      fribse @JerryP
                      @JerryP said in I can't get mmm-screencast to work:
                      nam install
                      Is that a new command? :-D
                        sdetweil @fribse
                        @fribse typo. npm
                          jste84 @JerryP
                          @JerryP ok so have done this. Git pull says up to date.
                          Npm install - installs with 12 vulnerabilities…
                          • JerryPJ
                            JerryP @jste84
                            @jste84 OK.
                            And now when you reboot the mirror.
                            Are u using the same wifi network for our phone and mirror. to broadcast YouTube?? Frome your laptop it’s not working. “At my place only the phone and iPad can connect the module”
                              jste84 @fribse
                              @fribse Shield is WiFi too…
                                jste84 @JerryP
                                @JerryP same Wifi network for the mirror and shield.
                                Reboot and when I open YouTube… Still no luck finding the mirror
                                • JerryPJ
                                  JerryP @jste84
                                  @jste84
                                  Can you try to put de Nvidia shield down. (unplug the power) and is I’t than possible tot see the screencast on the mirror (maybe reboot the mirror after you hef unplug the Nvidia shield)
                                  and kan you post one more time te config.
                                    jste84 @JerryP
                                    @JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
                                    module: 'MMM-Screencast',
                                    		position: 'bottom_right',
                                    			position: 'center',
                                    			castName: 'Mirror',
                                    			height: 300,
                                    			width: 500,
                                    S JerryPJ 2 Replies Last reply
                                      sdetweil @jste84
                                      @jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
                                      u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
                                      to allow machines (phone table laptop…) to connect to the mm server running the module
                                        jste84 @sdetweil
                                        @sdetweil how do I check for those?
                                        The address and ipWhitelist are both set this way.
                                        • JerryPJ
                                          JerryP @jste84
                                          @jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
                                          I’m thinking that you want something that’s not possible. Or I’m confused.
                                          The Shield is a different device. so unplug the power of it.
                                          Than take a phone whits is on the seem wifi network as the mirror
                                          Then use your phone en pick a movie on YouTube.com
                                          and hit the cast button.
                                          Your config looks oke.
                                          The pull is als don
                                          so I don’t know why it’s not working
                                          In the picture you can see my 2 mirrors.
                                          “Huiskamer”
                                          “Spiegeltje”
                                          • JerryPJ
                                            JerryP @jste84
                                            @jste84
                                            var config = {
                                            	address: "0.0.0.0"
                                            	port: 8080,
                                            	useHttps: false,
                                            	httpsPrivateKey: "",
                                            	httpsCertificate: "",
                                            	language: "nl",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            modules:
                                            This is my part of de var (ip handeling)
                                            S J 2 Replies Last reply
                                            • 2 / 3
