    I can't get mmm-screencast to work
    59 Posts 6 Posters 33.4k Views 6 Watching
    • JerryPJ Offline
      JerryP @fribse
      @fribse
      position: 'bottomCenter",
      This one is not in use.
      try this one
      position 'bottom_center'
      • JerryPJ Offline
        JerryP @fribse
        • F Offline
          fribse @JerryP
          @JerryP You’re right, ha ha, that’s been there for ages, it works, just places it in the middle of it all, but looks better at the bottom :-D
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @fribse
            @fribse So now whit the new line of code i’t a live.
            Lets stream YouTube.
            I use the module for the kids to see school movies. Home school. hahaha
            • F Offline
              fribse @JerryP
              @JerryP I wasn’t the OP, I never had a problem I just commented on how to post the code :-)
                jste84 @JerryP
                @JerryP I’ve copied your config and still can’t find the device. When I try and cast YouTube. The only device that shows is my Nvidia shield 😓
                • F Offline
                  fribse @jste84
                  @jste84 Are the pi on wifi or cable? It could be due to mDNS not propagating across wired/wireless.
                    jste84 @fribse
                    @fribse its wifi… Is there a way to check/fix this?
                    F JerryPJ 2 Replies Last reply Reply Quote 0
                    • F Offline
                      fribse @jste84
                      @jste84 As long as the devices are on the same, ie. both on cable, or both on wifi, then you should be good.
                      One thing I wonder though, the shield, is that on cable? It could be client isolation, if you have that activated on your wifi, then it won’t work.
                      • JerryPJ Offline
                        JerryP @jste84
                        @jste84
                        lets try to pull the module!!
                        Navigate to the modules directory via the follow command:
                        cd MagicMirror/modules/MMM-Screencast
                        git pull
                        npm install
                        F J 2 Replies Last reply Reply Quote 0
                        • F Offline
                          fribse @JerryP
                          @JerryP said in I can't get mmm-screencast to work:
                          nam install
                          Is that a new command? :-D
                            sdetweil @fribse
                            @fribse typo. npm
                              jste84 @JerryP
                              @JerryP ok so have done this. Git pull says up to date.
                              Npm install - installs with 12 vulnerabilities…
                              • JerryPJ Offline
                                JerryP @jste84
                                @jste84 OK.
                                And now when you reboot the mirror.
                                Are u using the same wifi network for our phone and mirror. to broadcast YouTube?? Frome your laptop it’s not working. “At my place only the phone and iPad can connect the module”
                                  jste84 @fribse
                                  @fribse Shield is WiFi too…
                                    jste84 @JerryP
                                    @JerryP same Wifi network for the mirror and shield.
                                    Reboot and when I open YouTube… Still no luck finding the mirror
                                    • JerryPJ Offline
                                      JerryP @jste84
                                      @jste84
                                      Can you try to put de Nvidia shield down. (unplug the power) and is I’t than possible tot see the screencast on the mirror (maybe reboot the mirror after you hef unplug the Nvidia shield)
                                      and kan you post one more time te config.
                                        jste84 @JerryP
                                        @JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
                                        module: 'MMM-Screencast',
                                        		position: 'bottom_right',
                                        			position: 'center',
                                        			castName: 'Mirror',
                                        			height: 300,
                                        			width: 500,
                                        S JerryPJ 2 Replies Last reply Reply Quote 0
                                          sdetweil @jste84
                                          @jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
                                          u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
                                          to allow machines (phone table laptop…) to connect to the mm server running the module
                                            jste84 @sdetweil
                                            @sdetweil how do I check for those?
                                            The address and ipWhitelist are both set this way.
                                            • 2 / 3
