    Show IP camera in Magic Mirror
    17 Posts 7 Posters 14.5k Views 8 Watching
    • Cr4z33C Offline
      Cr4z33 @drx1984
      @drx1984 try with MMM-FreeboxTV?
        drx1984 @Cr4z33
        @Cr4z33 said in Show IP camera in Magic Mirror:
        MMM-FreeboxTV
        you mean the module MMM-FreeBox-Monitor?
        Doesn’t work either.
        • BKeyportB Offline
          BKeyport Module Developer @drx1984
          @drx1984 Ahh! I originally had one of those in use. Using OMXPlayer directly is likely the best option.
          What I’ve done is block out a section of my screen using a custom module that’s not published, then, using a bash script, I launch OMX Player with a command line like:
          omxplayer --avdict rtsp_transport:tcp --live --orientation [rotation] --win "[X1 Y1 X2 Y2]" rtsp://[URL]
          “Rotation” is the rotation of your monitor, 0 (Normal), 90 (right portrait), 180 (upside down), 270 (left portrait)
          “X1” is the left X position NOT CONSIDERING ROTATION.
          “X2” is the right X position NOT CONSIDERING ROTATION.
          “Y1” is the top Y position NOT CONSIDERING ROTATION.
          “Y2” is the bottom Y position NOT CONSIDERING ROTATION.
          omxplayer will then launch on top of the mirror screen.
          Example:
          omxplayer --avdict rtsp_transport:tcp --live --orientation 90 --win "1500 325 1915 1075" rtsp://U:P@A/2/h265/major
          My screen is rotated right portrait, so I rotate OMX to match. (90)
          The window I need cut out is 700x415 pixels, my resolution is 1080x1920. You’ll notice I have it 5px off the edge to assure I see everything, and I’ve got it in the upper right corner of my display. my camera I use now instead of the Reolink is using that URL, even though it puts out a H264 stream at the moment (I’m looking for an option to go to H265 as h264 uses flash for display)
            jasondreher
            I am using iFrame. But also using BlueIris to stream the IP camera to a http site, makes things much easier, plus I can get motion from BlueIris.
            		module: 'MMM-iFrame',
            		position: 'bottom_left',	// This can be any of the regions.
            				url: ["http://192.XXX.X.XXX:XXXX/mjpg/CAM1/video.mjpg"],
            				updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
            				width: "1200px", // Optional. Default: 100%
            				height: "600px" //Optional. Default: 100px
            • BKeyportB Offline
              I now have MMM-FreeboxTV working displaying my IP Camera.
              Here’s the trick:
              Edit streamsConfig.json and strip out everything but channel 2.
              Channel 2 should be:
              "2": "rtsp://[url]"
              Then: in config.js
              	module: 'MMM-FreeboxTV',
              	position: 'top_right',
              		debug: false,
              		autoReplay: true,
              		fullscreen: false,
              		width: [to taste],
              		height: [to taste],
              		onStart: 2,
              		onStartDelay: 5000,
              		streams: "streamsConfig.json"
              PS: Because of my module size, I needed to still use my unlisted block module. :(
              D M 2 Replies Last reply Reply Quote 0
                drx1984 @BKeyport
                @BKeyport do you mean that
                Unfortunately I don’t see a stream either
                  drx1984 @jasondreher
                  @jasondreher Unfortunately, iframe does not work with Reolink cameras.
                  • BKeyportB Offline
                    @drx1984 you didn’t follow my directions. The system expects the channels in the json file.
                      drx1984 @BKeyport
                      @BKeyport Good morning thanks,
                      Everything works fine locally now.
                      But when I call up my MagicMirror via a browser on another computer via an IP address, there is no cam stream.
                      I think it only works locally?
                      Is there any other solution? Or at least display a picture from the IP camera?
                      • BKeyportB Offline
                        Sadly, no. Other programs had a option for a remote feed, like using OMXPlayer locally, and mmfpeg remotely, but those are abandoned.
                        • G Offline
                          goprojojo @drx1984
                          @drx1984 That’s too bad. Hope there is a solution for Reolink. Any confirmed camera brand that does work with MMM-FreeboxTV?
                          • BKeyportB Offline
                            BKeyport Module Developer @goprojojo
                            @goprojojo If it works with VLC, it’ll work with Freebox. go to https://www.ispyconnect.com/man.aspx?n=Reolink to get the URL you’ll need, and try it on VLC.
                              meaple @BKeyport
                              @bkeyport Got my streamsConfig.json set (also tried without [])17d988e5-4ac0-436b-b33e-3ce815f9b19c-image.png and free box set in config.js bf138c16-30b5-4411-8fbe-319ea0423ce4-image.png
                              Any idea?
                              • H Offline
                                hrmax23
                                Anyone happen to know where I can find MMM-FreeboxTV?
