    Show IP camera in Magic Mirror
    17 Posts 7 Posters 14.5k Views 8 Watching
      jasondreher
      I am using iFrame. But also using BlueIris to stream the IP camera to a http site, makes things much easier, plus I can get motion from BlueIris.
      		module: 'MMM-iFrame',
      		position: 'bottom_left',	// This can be any of the regions.
      				url: ["http://192.XXX.X.XXX:XXXX/mjpg/CAM1/video.mjpg"],
      				updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
      				width: "1200px", // Optional. Default: 100%
      				height: "600px" //Optional. Default: 100px
      • BKeyportB Offline
        BKeyport Module Developer
        I now have MMM-FreeboxTV working displaying my IP Camera.
        Here’s the trick:
        Edit streamsConfig.json and strip out everything but channel 2.
        Channel 2 should be:
        "2": "rtsp://[url]"
        Then: in config.js
        	module: 'MMM-FreeboxTV',
        	position: 'top_right',
        		debug: false,
        		autoReplay: true,
        		fullscreen: false,
        		width: [to taste],
        		height: [to taste],
        		onStart: 2,
        		onStartDelay: 5000,
        		streams: "streamsConfig.json"
        PS: Because of my module size, I needed to still use my unlisted block module. :(
        D M 2 Replies Last reply Reply Quote 0
          drx1984 @BKeyport
          @BKeyport do you mean that
          Unfortunately I don’t see a stream either
            drx1984 @jasondreher
            @jasondreher Unfortunately, iframe does not work with Reolink cameras.
            • BKeyportB Offline
              BKeyport Module Developer @drx1984
              @drx1984 you didn’t follow my directions. The system expects the channels in the json file.
                drx1984 @BKeyport
                @BKeyport Good morning thanks,
                Everything works fine locally now.
                But when I call up my MagicMirror via a browser on another computer via an IP address, there is no cam stream.
                I think it only works locally?
                Is there any other solution? Or at least display a picture from the IP camera?
                • BKeyportB Offline
                  Sadly, no. Other programs had a option for a remote feed, like using OMXPlayer locally, and mmfpeg remotely, but those are abandoned.
                  • G Offline
                    goprojojo @drx1984
                    @drx1984 That’s too bad. Hope there is a solution for Reolink. Any confirmed camera brand that does work with MMM-FreeboxTV?
                    • BKeyportB Offline
                      BKeyport Module Developer @goprojojo
                      @goprojojo If it works with VLC, it’ll work with Freebox. go to https://www.ispyconnect.com/man.aspx?n=Reolink to get the URL you’ll need, and try it on VLC.
                        meaple @BKeyport
                        @bkeyport Got my streamsConfig.json set (also tried without [])17d988e5-4ac0-436b-b33e-3ce815f9b19c-image.png and free box set in config.js bf138c16-30b5-4411-8fbe-319ea0423ce4-image.png
                        Any idea?
                        • H Offline
                          hrmax23
                          Anyone happen to know where I can find MMM-FreeboxTV?
