    MMM-Worldclock
    39 Posts 9 Posters 18.7k Views 9 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Update: As of 1/18/21 - new feature - You now may use a flag of your choice, using the altflag command.
      It’s not perfect, but it’s there.
      			module: "MMM-Worldclock",
      				style: "right",
      				offsetTimezone: null,
      				clocks: [
      						title: "Local",
      						timezone: "America/Los_Angeles",
      						altflag: "washington.png",
      						timeFormat: "hh:mm:ss a",
      						title: "ET",
      						timezone: "America/New_York",
      						flag: "us",
      						timeFormat: "hha MM/DD",
      						title: "CT",
      						timezone: "America/Chicago",
      						flag: "us",
      						title: "MT",
      						timezone: "America/Boise",
      						flag: "us",
      						title: "AK",
      						timezone: "America/Anchorage",
      						flag: "us",
      						title: "HI",
      						timezone: "Pacific/Honolulu",
      						flag: "us",
      						title: "UTC",
      						timezone: "UTC",
      						timeFormat: "HH:mm MM/DD",
      						altflag: "world.jpg"
        JohnGalt
        Thanks for the module. I have installed it and have it working, but do have one question: How do I keep the top ‘home’ time zone from displaying? I already have the clock module running, so I don’t need a 2nd module telling me the local time… Unfortunately, when i remove the code for the home timezone, it still displays. Thanks in advance,
        • BKeyportB Offline
          BKeyport Module Developer @JohnGalt
          @JohnGalt Let me see your config, that’s really odd…(JUST the config for Worldclock/MMM-Worldclock, no need for the rest)
          1 Reply Last reply Reply Quote -1
            JohnGalt
            Here you go:
            { module: “MMM-Worldclock”,
            position: “bottom_right”, // This can be any of the regions, best results in top_left or top_right regions
            config: { // See ‘Configuration options’ for more information.
            timeFormat: ‘hh:mm A’, //defined in moment.js format()
            style: ‘top’, //predefined 4 styles; ‘top’, ‘left’,‘right’,‘bottom’
            offsetTimezone: null, // Or you can set Europe/Berlin to get timegap difference from this timezone. null will be UTC timegap.
            clocks: [
            { title: “Home”,
            flag: “us” },
            title: “Italy”,
            timezone: “Europe/Rome”,
            flag: “it”,
            title: “Durban, So Africa”, // Too long title could cause ugly text align.
            timezone: “Africa/Johannesburg”, //When omitted, Localtime will be displayed. It might be not your purporse, I bet.
            flag: “za”,
            { title: “Aruba”,
            timezone: “America/Curacao”,
            flag: “aw”,
            ] // Close clocks list
            } // Close Worldclock config
            }, // Close module MMM-Worldclock
              JohnGalt
              Hummm - It looks like the forum stripped out leading tabs and/or spaces, but the content look OK…
              • BKeyportB Offline
                @JohnGalt didn’t mark it as code… use ``` at the beginning and ending of the code to show it as pasted.
                To remove the home timezone, just remove it, including the opening and closing bracket.
                You don’t need to specify your local time zone. In my examples, I only use MMM-Worldclock to display the time on my mirror, so I need a local view. I pasted the code adjustment below, didn’t retab it, and I may have missed a few “adjusted” quotes, so if MM don’t like it, check the quotes.
                clocks: [
                title: "Italy",
                timezone: "Europe/Rome",
                flag: "it",
                title: "Durban, So Africa", // Too long title could cause ugly text align.
                timezone: "Africa/Johannesburg", //When omitted, Localtime will be displayed. It might be not your purporse, I bet.
                flag: "za",
                title: "Aruba",
                timezone: "America/Curacao",
                flag: "aw",
                  JohnGalt @BKeyport
                  @bkeyport - Thanks! It works as you describe. I thought I had already tried removing that code to no avail, but obviously hadn’t. Thanks again!
                  • BKeyportB Offline
                    NOTICE: As of the current moment, this module is not behaving well with MagicMirror 2.16. The module comes up smaller than intended.
                    As such, the workaround is as follows:
                    in custom.css
                    .MMM-Worldclock .main {
                      font-size: 1.65rem;
                    .MMM-Worldclock .caption {
                      font-size: 1rem;
                    Hopefully the font generation in MagicMirror will go back to normal in a couple of releases. Of course, you can adjust the font sizes as you please.
                      MacG
                      It’s a superb module but needs some CSS adjustments. Thanks for the helpful hints here in the thread.
                      Is it possible to update the clock only when the time has changed? The current refresh is every second, but I only use a clock with hours and minutes.
                      That might also lower the load on the browser and it would probably be helpful for CSS customizations via the browser developer tools.
                      BKeyportB S 2 Replies Last reply Reply Quote 0
                      • BKeyportB Offline
                        BKeyport Module Developer @MacG
                        @macg I doubt there’d be any performance boost, as the whole browser/javascript is constantly scanning for changes. The original code this is based on used the second for the refresh as it assumes the second would be the minimum displayed unit.
                        There’s really no such thing as idle anymore.
                        As for CSS - please, adjust it, adding to your custom.css file - and publish what you do here. Sean’s CSS is good, mine is weaker, but I’m learning and playing at the pace my job allows. Changes that I evaluate would help the core will be included.
                        • 1 / 4
