    MMM-Awesome-Alexa Trouble
    18 Posts 5 Posters 5.4k Views 5 Watching
      sdetweil @xfqbe
      @xfqbe not really.
      what did the electron-rebuild say?
      X 1 Reply Last reply Reply Quote 0
        sdetweil @xfqbe
        @xfqbe did u do all the instruction steps? some 15 of them
        • X
          xfqbe @sdetweil
          @sdetweil The electron-rebuild was normal without any error codes and yes I followed these steps. https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
            sdetweil @xfqbe
            @xfqbe no. the instructions in the module.
            i compiled fine
            see the readme
            • H
              hectoreg21
              Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.
              Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.
              It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.
              Let me know if this helped you!
              Have fun!!
                sdetweil @hectoreg21
                @hectoreg21 but when u git clone it uses the project name so this shouldn’t happen
                • H
                  hectoreg21 @sdetweil
                  @sdetweil You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.
                  And thanks for the reply!
                    @hectoreg21 unless u are following some old workbook of instructions
                      shagtimetim @sdetweil
                      The information related to the capitalization is found on the developers install page. He specifically calls out “MMM-awesome-alexa”. However, I have yet to get this module to function. Each time I add to the MM config, the black screen with cursor appears.
                        sdetweil @shagtimetim
                        @shagtimetim i created a script of his steps,
                        make executable.
                        doinstall.sh
                        does all the module install steps, so remove the current awesome-alexa module folder, ignore the errors, only result of last step matters
                          @sdetweil Thank you! Installing now. Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?
                            @shagtimetim it will do that just hang on,
                            all this does is take the steps on the wiki make them run in a script
                            it does fix one dependency correction
                            this is what my stuff does just a copy/paste
                            https://awesome-alexa.js.org/#/installation
                              @sdetweil Thank you!! Everything now working as designed. One day, I will learn json!!!
                                jste84 @shagtimetim
                                @shagtimetim you got this module working?
                                  shagtimetim @jste84
                                  @jste84 I have no issues since I used Sam’s steps
