    MMM-Awesome-Alexa Trouble
    18 Posts 5 Posters 4.5k Views 5 Watching
    • X Offline
      xfqbe @sdetweil
      @sdetweil The electron-rebuild was normal without any error codes and yes I followed these steps. https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
        sdetweil @xfqbe
        @xfqbe no. the instructions in the module.
        i compiled fine
        see the readme
        • H Offline
          hectoreg21
          Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.
          Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.
          It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.
          Let me know if this helped you!
          Have fun!!
            sdetweil @hectoreg21
            @hectoreg21 but when u git clone it uses the project name so this shouldn’t happen
            • H Offline
              hectoreg21 @sdetweil
              @sdetweil You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.
              And thanks for the reply!
                @hectoreg21 unless u are following some old workbook of instructions
                  shagtimetim @sdetweil
                  The information related to the capitalization is found on the developers install page. He specifically calls out “MMM-awesome-alexa”. However, I have yet to get this module to function. Each time I add to the MM config, the black screen with cursor appears.
                    sdetweil @shagtimetim
                    @shagtimetim i created a script of his steps,
                    make executable.
                    doinstall.sh
                    does all the module install steps, so remove the current awesome-alexa module folder, ignore the errors, only result of last step matters
                      @sdetweil Thank you! Installing now. Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?
                        @shagtimetim it will do that just hang on,
                        all this does is take the steps on the wiki make them run in a script
                        it does fix one dependency correction
                        this is what my stuff does just a copy/paste
                        https://awesome-alexa.js.org/#/installation
                          @sdetweil Thank you!! Everything now working as designed. One day, I will learn json!!!
                            jste84 @shagtimetim
                            @shagtimetim you got this module working?
                              shagtimetim @jste84
                              @jste84 I have no issues since I used Sam’s steps
