    MMM-Awesome-Alexa Trouble
    18 Posts 5 Posters 5.3k Views 5 Watching
    • H Offline
      hectoreg21
      Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.
      Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.
      It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.
      Let me know if this helped you!
      Have fun!!
        sdetweil @hectoreg21
        @hectoreg21 but when u git clone it uses the project name so this shouldn’t happen
        • H Offline
          hectoreg21 @sdetweil
          @sdetweil You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.
          And thanks for the reply!
            @hectoreg21 unless u are following some old workbook of instructions
              shagtimetim @sdetweil
              The information related to the capitalization is found on the developers install page. He specifically calls out “MMM-awesome-alexa”. However, I have yet to get this module to function. Each time I add to the MM config, the black screen with cursor appears.
                sdetweil @shagtimetim
                @shagtimetim i created a script of his steps,
                make executable.
                doinstall.sh
                does all the module install steps, so remove the current awesome-alexa module folder, ignore the errors, only result of last step matters
                  @sdetweil Thank you! Installing now. Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?
                    @shagtimetim it will do that just hang on,
                    all this does is take the steps on the wiki make them run in a script
                    it does fix one dependency correction
                    this is what my stuff does just a copy/paste
                    https://awesome-alexa.js.org/#/installation
                      @sdetweil Thank you!! Everything now working as designed. One day, I will learn json!!!
                        jste84 @shagtimetim
                        @shagtimetim you got this module working?
                          shagtimetim @jste84
                          @jste84 I have no issues since I used Sam’s steps
