    MMM-Awesome-Alexa Trouble
    18 Posts 5 Posters 5.3k Views 5 Watching
    • X Offline
      xfqbe
      Hey! I was wondering if anyone could help me figure out how to fix this. When I startup the mirror I get this error and the screen is just pitch black with no modules. Any help would be appreciated, thanks!
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module
      ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js
      • /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js
        sdetweil @xfqbe
        @xfqbe maybe
        do
        npm install electron-rebuild
        cd modules/MMM-Awesome-Alexa
        ~/MagicMirror/node_modules/.bin/electron-rebuild
        let us know
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          xfqbe @sdetweil
          @sdetweil Thanks for replying, I did exactly what you said correctly and it’s still showing the same errors :/ Is there anything else I should try? or maybe a different Alexa module?
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
          Require stack:
            sdetweil @xfqbe
            @xfqbe not really.
            what did the electron-rebuild say?
              sdetweil @xfqbe
              @xfqbe did u do all the instruction steps? some 15 of them
              • X Offline
                xfqbe @sdetweil
                @sdetweil The electron-rebuild was normal without any error codes and yes I followed these steps. https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                  sdetweil @xfqbe
                  @xfqbe no. the instructions in the module.
                  i compiled fine
                  see the readme
                  • H Offline
                    hectoreg21
                    Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.
                    Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.
                    It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.
                    Let me know if this helped you!
                    Have fun!!
                      sdetweil @hectoreg21
                      @hectoreg21 but when u git clone it uses the project name so this shouldn’t happen
                      • H Offline
                        hectoreg21 @sdetweil
                        @sdetweil You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.
                        And thanks for the reply!
                          @hectoreg21 unless u are following some old workbook of instructions
                            shagtimetim @sdetweil
                            The information related to the capitalization is found on the developers install page. He specifically calls out “MMM-awesome-alexa”. However, I have yet to get this module to function. Each time I add to the MM config, the black screen with cursor appears.
                              sdetweil @shagtimetim
                              @shagtimetim i created a script of his steps,
                              make executable.
                              doinstall.sh
                              does all the module install steps, so remove the current awesome-alexa module folder, ignore the errors, only result of last step matters
                                @sdetweil Thank you! Installing now. Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?
                                  @shagtimetim it will do that just hang on,
                                  all this does is take the steps on the wiki make them run in a script
                                  it does fix one dependency correction
                                  this is what my stuff does just a copy/paste
                                  https://awesome-alexa.js.org/#/installation
                                    @sdetweil Thank you!! Everything now working as designed. One day, I will learn json!!!
                                      jste84 @shagtimetim
                                      @shagtimetim you got this module working?
                                        shagtimetim @jste84
                                        @jste84 I have no issues since I used Sam’s steps
