    MMM-Awesome-Alexa Trouble
    18 Posts 5 Posters 5.5k Views 5 Watching
      sdetweil @xfqbe
      @xfqbe no. the instructions in the module.
      i compiled fine
      see the readme
      • H
        hectoreg21
        Hi!! I don’t know if you are still interested or if you already figured it out, but it happened to me too and have just found a fix. So here it is, for you, or whomever may need it.
        Go to the MagicMirror folder, get inside modules, and rename the folder “MMM-awesome-alexa” to “MMM-Awesome-Alexa”.
        It seems like the program is Capitals sensitive and couldn’t find the pathway. After renaming, it stopped giving back those errors.
        Let me know if this helped you!
        Have fun!!
          sdetweil @hectoreg21
          @hectoreg21 but when u git clone it uses the project name so this shouldn’t happen
          H 1 Reply Last reply
          • H
            hectoreg21 @sdetweil
            @sdetweil You are so true! The program does not give back any errors at all, but Alexa does not work either (because of the pathway name change). Sorry I didn’t notice this before posting. I’ll keep looking into it.
            And thanks for the reply!
              @hectoreg21 unless u are following some old workbook of instructions
                shagtimetim @sdetweil
                The information related to the capitalization is found on the developers install page. He specifically calls out “MMM-awesome-alexa”. However, I have yet to get this module to function. Each time I add to the MM config, the black screen with cursor appears.
                  sdetweil @shagtimetim
                  @shagtimetim i created a script of his steps,
                  make executable.
                  doinstall.sh
                  does all the module install steps, so remove the current awesome-alexa module folder, ignore the errors, only result of last step matters
                    @sdetweil Thank you! Installing now. Being a confirmed noob to MM, can you advise on this step “Build snowboy to your device specifications, in the /snowboy directory”?
                      @shagtimetim it will do that just hang on,
                      all this does is take the steps on the wiki make them run in a script
                      it does fix one dependency correction
                      this is what my stuff does just a copy/paste
                      https://awesome-alexa.js.org/#/installation
                        @sdetweil Thank you!! Everything now working as designed. One day, I will learn json!!!
                        J 1 Reply Last reply
                          jste84 @shagtimetim
                          @shagtimetim you got this module working?
                            shagtimetim @jste84
                            @jste84 I have no issues since I used Sam’s steps
