    Currency Exchange Rates?
    22 Posts 8 Posters 20.5k Views 8 Watching
    • E
      elmerito25 @yawns
      @yawns Maybe similar like this: 0_1480528611146_andorid2.jpg It would be nice to have a base currency and then list the exchange rates for major currencies (USD/GBP/EUR…). Maybe an array of currencies so users can pick and choose what currency exchange rates they want to show.
      Thanks in advance!
      • CatoC
        Cato Module Developer
        How many currencies are people really interested to follow on their mirror? 1? 3? 5? 10? More? This number would dictate the layout of the module.
        I’m considering a module for my self, but I basically just need 1 (THB/NOK).
        yawnsY 1 Reply Last reply
        • yawnsY
          yawns Moderator @Cato
          @Cato
          Right, that’s my concern too. I don’t want to overload the mirrors space
          Maybe I can add some logic to choose the layout based on the number of currencies chosen
          E 1 Reply Last reply
          • E
            elmerito25 @yawns
            @yawns Agreed. Maybe a maximum of 3 currencies?
            • yawnsY
              yawns Moderator
              all right everyone, I did some progress on the module. Please take a look at it and let me know your thoughts.
              Features:
              • ticker mode - displays all selected currencies in a marquee ticker, main use in my opinion is in bottom_bar or top_bar
              • table mode - display all selected currencies in a table. Up to 8 currencies are split into 2 columns, anything above is split into 3 columns
              • you can hide/show the curreny flag and the currency code/abbreviation
              • you can display a custom header above the output to show your selected base currency and the date of the data
              Question: Does anyone know if and how I could manipulate the original header to avoid the custom header thing and still display base currency and date?
              One notice: data is provided by fixer.io which is updating their data once a day. There are other apis for currency rates but you cannot select your own base currency if you are on a free plan. Means you would have to pay for it
              [card:yawnsde/MMM-CurrencyExchange]
              F A 2 Replies Last reply
              • F
                foggy @yawns
                @yawns Super job. Thank you. Works well.
                Is it possible to define which currency is displayed first?
                Just in case another newbie comes along. the last (,) comma is in the wrong place and should be moved to the end.
                Best wishes.
                • yawnsY
                  yawns Moderator
                  I guess I could add some sorting mechanism, maybe based on the array order.
                  Which comma exactly? I’m just on my smartphone, so I might oversee it
                  F 1 Reply Last reply
                  • F
                    foggy @yawns
                    @yawns The one on the penultimate line.
                    module: ‘MMM-CurrencyExchange’,
                    position: ‘top_right’,
                    base: ‘EUR’,
                    symbols: [‘GBP’, ‘USD’]
                    • yawnsY
                      yawns Moderator
                      Thanks. Fixed!
                      • CatoC
                        Great module - works perfectly!
                        I’m not sure if this is just me, but for some currencies I like to switch the base currency because that makes more sence to me.
                        Suggestion: make an array of base/currencies, like this:
                        currencies: [
                              { base: 'NOK', symbol 'THB' },
                              { base: 'EUD', symbol 'NOK' },
                              { base: 'USD', symbol 'NOK' }
                        A little harder to configure, but much more flexible.
                        Again - not sure if this is for everyone… (?)
                        • yawnsY
                          yawns Moderator
                          Nice idea!
                          I’m at home on Wednesday, I guess I’ll find some time to look at this. Would require more api requests or more conversion and math.
                          • F
                            frog @yawns
                            @yawns Hi,
                            How often does this refresh? I’m getting no changes on my mirror even though I’m restarting it.
                            • yawnsY
                              yawns Moderator
                              The api provider is http://fixer.io and updates once a day. If you check the website and click on the first code snippet it should unfold and show the latest update including exchange rates. Does this match with what you see on the mirror? Or is the data on your mirror older?
                              You could enable the customHeader, then the update date is shown as retrieved from the api
                              F E 2 Replies Last reply
                              • F
                                frog @yawns
                                @yawns thanks. The date says a day out I.e the 5th for today (the 6th). I wasn’t aware of only a daily update, so it must be working OK. Thanks
                                • E
                                  elmerito25 @yawns
                                  @yawns Appreciate developing this module. Just added this to my “soon-to-be-completed” MM and looks good!
                                  • A
                                    AviY @yawns
                                    • ndtrunghieuN
                                      ndtrunghieu
                                      Hi guy,
                                      Please help me, how to add VND and Vietnam FLAG? Please help me to check my file config.
                                      Jason Nguyen
                                      • bheplerB
                                        bhepler Module Developer
                                        I followed the code back to the API it is accessing from the European Central Bank. VND is not a supported currency.
