This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MMM-assistant2display youtube video
Hello, I have a problem with MMM-assistant2display after the voice command they don’t display video.
Configuration File :
var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" electronOptions: { webPreferences : { webviewTag: true } }, port: 8080, basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, { module: "MMM-GoogleAssistant", position: "fullscreen_above", config: { debug: false, assistantConfig: { lang: "en-US", projectId: "", // Required to use gaction. modelId: "", // (OPTIONAL for gaction) instanceId: "", // (OPTIONAL for gaction) latitude: 51.508530, longitude: -0.076132, }, responseConfig: { useScreenOutput: true, screenOutputCSS: "screen_output.css", screenOutputTimer: 5000, screenRotate: false, activateDelay: 250, useAudioOutput: true, useChime: true, newChime: false, useNative: true, playProgram: "mpg321" }, micConfig: { // put there configuration generated by auto-installer recorder: "arecord", device: "plughw:0", }, snowboy: { useSnowboy: true, usePMDL: false, audioGain: 2.0, Frontend: true, Model: "jarvis", Sensitivity: null }, A2DServer: { useA2D: true, stopCommand: "stop", useYouTube: true, youtubeCommand: "youtube", displayResponse: true }, recipes: [ "with-MMM-TelegramBot.js" ], NPMCheck: { useChecker: true, delay: 10 * 60 * 1000, useAlert: true } } }, { module: "MMM-Assistant2Display", position: "top_left", config: { debug:false, useYoutube: true, links: { useLinks: false, displayDelay: 60 * 1000, scrollStep: 25, scrollInterval: 1000, scrollStart: 5000, scrollActivate: false, verbose: false }, photos: { usePhotos: true, displayDelay: 10 * 1000 }, volume: { useVolume: true, volumePreset: "ALSA", myScript: null }, briefToday: { useBriefToday: false, welcome: "brief Today" }, screen: { useScreen: false, delay: 5 * 60 * 1000, turnOffDisplay: true, mode: 1, ecoMode: true, displayCounter: true, displayBar: false, displayStyle: "Text", text: "Auto Turn Off Screen:", detectorSleeping: false, governorSleeping: false, displayLastPresence: true, LastPresenceText: "Last Presence:", delayed: 0 }, touch: { useTouch: false, mode: 3 }, pir: { usePir: false, gpio: 21, reverseValue: false }, governor: { useGovernor: false, sleeping: "powersave", working: "ondemand" }, internet: { useInternet: true, displayPing: false, delay: 2* 60 * 1000, scan: "google.fr", command: "pm2 restart 0", showAlert: true }, cast: { useCast: false, castName: "MagicMirror_A2D", port: 8569 }, spotify: { useSpotify: false, useBottomBar: false, useLibrespot: false, connectTo: null, playDelay: 3000, minVolume: 10, maxVolume: 100, updateInterval: 1000, idleInterval: 10000, username: "", password: "", CLIENT_ID: "", CLIENT_SECRET: "", deviceDisplay: "Listening on", usePause: true, typeArtist: "artist", typePlaylist: "playlist", typeAlbum: "album", typeTrack: "track" }, NPMCheck: { useChecker: true, delay: 10 * 60 * 1000, useAlert: true } } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
~~assistant2display is no longer supported. the author left mm over a year ago.
this has been replaced by MMM-GoogleAssistant and Assistant2Display, by bugsounet.~~
he does support on his own forum
@sdetweil thanx for your reponse ,
Yes, if you see in my script I’m using the MMM-googleassistant + Assistant2Display
@sdetweil can you troubleshoot with me please?
@youssef no, sorry, no idea how the module works…
@sdetweil hello SAM thanks for your response I just reinstall the module it’s work
@youssef awesome. did u do anything different?
@sdetweil I just reinstall Assistant2display
