    MMM-assistant2display youtube video
    9 Posts 2 Posters 2.0k Views 2 Watching
    • Y
      youssef
      Hello, I have a problem with MMM-assistant2display after the voice command they don’t display video.
      Y 1 Reply Last reply
      • Y
        youssef @youssef
        Configuration File :
        var config = {
        	address: "localhost", 	// Address to listen on, can be:
        electronOptions: {
                 webPreferences : {
                      webviewTag: true
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check",
        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        			module: "weatherforecast",
        			header: "Weather Forecast",
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
          module: "MMM-GoogleAssistant",
          position: "fullscreen_above",
            debug: false,
            assistantConfig: {
              lang: "en-US",
              projectId: "", // Required to use gaction.
              modelId: "", // (OPTIONAL for gaction)
              instanceId: "", // (OPTIONAL for gaction)
              latitude: 51.508530,
              longitude: -0.076132,
            responseConfig: {
              useScreenOutput: true,
              screenOutputCSS: "screen_output.css",
              screenOutputTimer: 5000,
              screenRotate: false,
              activateDelay: 250,
              useAudioOutput: true,
              useChime: true,
              newChime: false,
              useNative: true,
              playProgram: "mpg321"
            micConfig: { // put there configuration generated by auto-installer
              recorder: "arecord",
              device: "plughw:0",
            snowboy: {
              useSnowboy: true,
              usePMDL: false,
              audioGain: 2.0,
              Frontend: true,
              Model: "jarvis",
              Sensitivity: null
            A2DServer: {
              useA2D: true,
              stopCommand: "stop",
              useYouTube: true,
              youtubeCommand: "youtube",
              displayResponse: true
            recipes: [ "with-MMM-TelegramBot.js" ],
            NPMCheck: {
              useChecker: true,
              delay: 10 * 60 * 1000,
              useAlert: true
          module: "MMM-Assistant2Display",
            debug:false,
            useYoutube: true,
            links: {
              useLinks: false,
              displayDelay: 60 * 1000,
              scrollStep: 25,
              scrollInterval: 1000,
              scrollStart: 5000,
              scrollActivate: false,
              verbose: false
            photos: {
              usePhotos: true,
              displayDelay: 10 * 1000
            volume: {
              useVolume: true,
              volumePreset: "ALSA",
              myScript: null
            briefToday: {
              useBriefToday: false,
              welcome: "brief Today"
            screen: {
              useScreen: false,
              delay: 5 * 60 * 1000,
              turnOffDisplay: true,
              mode: 1,
              ecoMode: true,
              displayCounter: true,
              displayBar: false,
              displayStyle: "Text",
              text: "Auto Turn Off Screen:",
              detectorSleeping: false,
              governorSleeping: false,
              displayLastPresence: true,
              LastPresenceText: "Last Presence:",
              delayed: 0
            touch: {
              useTouch: false,
              mode: 3
            pir: {
              usePir: false,
              gpio: 21,
              reverseValue: false
            governor: {
              useGovernor: false,
              sleeping: "powersave",
              working: "ondemand"
            internet: {
              useInternet: true,
              displayPing: false,
              delay: 2* 60 * 1000,
              scan: "google.fr",
              command: "pm2 restart 0",
              showAlert: true
            cast: {
              useCast: false,
              castName: "MagicMirror_A2D",
              port: 8569
            spotify: {
              useSpotify: false,
              useBottomBar: false,
              useLibrespot: false,
              connectTo: null,
              playDelay: 3000,
              minVolume: 10,
              maxVolume: 100,
              updateInterval: 1000,
              idleInterval: 10000,
              username: "",
              password: "",
              CLIENT_ID: "",
              CLIENT_SECRET: "",
              deviceDisplay: "Listening on",
              usePause: true,
              typeArtist: "artist",
              typePlaylist: "playlist",
              typeAlbum: "album",
              typeTrack: "track"
            NPMCheck: {
              useChecker: true,
              useAlert: true
          sdetweil @youssef
          @youssef
          ~~assistant2display is no longer supported. the author left mm over a year ago.
          this has been replaced by MMM-GoogleAssistant and Assistant2Display, by bugsounet.~~
          he does support on his own forum
          https://bugsounet.forums.fr
          • Y
            youssef
            @sdetweil thanx for your reponse ,
            Yes, if you see in my script I’m using the MMM-googleassistant + Assistant2Display
            • Y
              youssef
              @sdetweil can you troubleshoot with me please?
                sdetweil @youssef
                @youssef no, sorry, no idea how the module works…
                • Y
                  youssef @sdetweil
                  @sdetweil hello SAM thanks for your response I just reinstall the module it’s work
                    sdetweil @youssef
                    @youssef awesome. did u do anything different?
                    • Y
                      youssef @sdetweil
                      @sdetweil I just reinstall Assistant2display
