    Help please
    5 Posts 3 Posters 1.2k Views 3 Watching
    • I Offline
      innovation
      Hello, for my project I want to add multiple different screens - like an app. The monitor I bought is not a touch one so it cannot work like an iPad.
      So can I add multiple screens and with the voice command of “next” can it switch to another screen? How can I do that if it is possible?
      This would really help me. Thank you
        @innovation There are a few ways to do this. I’ve done this for a kitchen display where I have several pages that rotate in sequence, but are also controlled manually with an IR remote control (using the LEFT/RIGHT buttons to go to previous.next pages).
        I’m using a combination of the Profile Switcher module (https://github.com/tosti007/MMM-ProfileSwitcher.git) and my own Profile Carousel module the I wrote to handle input from the IR remote (https://github.com/jclarke0000/MMM-ProfileCarousel).
        My config looks like this:
              module: "MMM-ProfileSwitcher",
              disabled: false,
                defaultClass: "L_CALENDAR",
                everyoneClass: "L_ALL",
                includeEveryoneToDefault: true,
                defaultTime: 10000,
                useLockStrings: true
                // animationDuration: 500,
                // timers: {
                //   "L_CALENDAR" : {
                //     profile: "L_FORECAST"
                //   "L_FORECAST" : {
                //     profile: "L_CALENDAR"
              module: "MMM-ProfileCarousel",
              disabled: false,
                profiles: ["L_CALENDAR","L_FORECAST","L_NOTES"],
                carouselDelay: 10000, //10 seconds
                carouselResumeDelay: 1 * 30 * 1000, //30 seconds
                useScreensaver: true,
                screensaverProfile: "L_WORDCLOCK",
                screensaverTimeout: 1.25 * 60 * 1000,
                screensaverBlackoutPeriod: {
                  start: 11,
                  end: 12
        And every module has one or more class names applied that indicate which profile the module should be visible for:
        The clock module is visible for all profiles, so it looks like this:
              module: "clock",
              classes: "L_CALENDAR L_FORECAST L_NOTES",
                timeFormat: 12,
                showPeriod: true,
                displaySeconds: false
        While my weather module is only available on one page, so it looks like this:
              module: "MMM-OpenWeatherForecast",
              header: "Forecast",
              classes: "L_FORECAST",
              disabled: false,
        In your case, you’ll need to work with one of the Voice modules to provide input to Profile Switcher. You can explicitly set the current profile using the sendNotification function:
          this.sendNotification("CURRENT_PROFILE",  "profile name");
          sdetweil @innovation
          @innovation I think u can do this with MMM-Pages and MMM-Swipe.
          pages does the same classes organization of modules, and swipe handles sending notifications to pages to change to different psges
          • I Offline
            innovation @j.e.f.f
            @j-e-f-f
            Thank you so much. Checking right away
            • I Offline
              innovation @sdetweil
              @sdetweil Thank you! On it!
