    Got error when run MM 2.14.0
    11 Posts 2 Posters 7.3k Views 2 Watching
    • slametpsS Offline
      slametps
      I’m installing a new fresh MM 2.14.0 using installation script . After everything seems OK through installation, but the MM is not loaded. MM and PM2 is installed successfully. When I tried to run manually, got the following error:
      pi@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.14.0 start /home/pi/MagicMirror
      > ./run-start.sh $1
      ./run-start.sh: line 41: [: too many arguments
      [07.03.2021 16:04.29.213] [ERROR] App threw an error during load
      [07.03.2021 16:04.29.233] [ERROR] Error: Cannot find module 'lodash'
      Require stack:
      - /home/pi/MagicMirror/node_modules/express-ipfilter/lib/ipfilter.js
      - /home/pi/MagicMirror/node_modules/express-ipfilter/index.js
      - /home/pi/MagicMirror/js/server.js
          at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
          at Function../lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)
          at Module._load (internal/modules/cjs/loader.js:691:27)
          at Function.Module._load (electron/js2c/asar.js:748:26)
          at Module.require (internal/modules/cjs/loader.js:853:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express-ipfilter/lib/ipfilter.js:12:11)
          at Module._compile (internal/modules/cjs/loader.js:968:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
          at Module.load (internal/modules/cjs/loader.js:816:32)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      What’s wrong? Any one have the same/similar problem and already had the solution?
      Thx.
      regards,
      Slamet PS
      S 3 Replies Last reply Reply Quote 0
        sdetweil @slametps
        @slametps I will look at the run-start problem,
        but it appears install did not complete.
        can u post the ~/install.log file
        please use the code block markers
        select the text after lasting it, then push the button that looks like < />
          sdetweil @slametps
          @slametps to fix the run-start.sh problem do
          cd  ~/MagicMirror
          curl  -sL  https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
            sdetweil @slametps
            @slametps also, did u edit the config.js and change ipWhitelist at all?
            slametpsS 1 Reply Last reply Reply Quote 0
            • slametpsS Offline
              slametps @sdetweil
              @sdetweil : no, it is a fresh install.
              Here is the link to install.log
              regards,
              Slamet PS
              • slametpsS Offline
                slametps @slametps
                @slametps said in Got error when run MM 2.14.0:
                The raspberry is also a fresh install, I created the disk using Raspberry Pi Imager.
                regards,
                Slamet PS
                  sdetweil @slametps
                  @slametps ok, don’t know what happened… looks like u ran install 5 separate times…
                  so lets do this
                  rm  package-lock.json
                  rm -rf node_modules
                  npm install --only=prod
                  then try to start MM,
                  npm start
                  slametpsS 2 Replies Last reply Reply Quote 0
                  • slametpsS Offline
                    slametps @sdetweil
                    @sdetweil said in Got error when run MM 2.14.0:
                    so lets do this
                    rm -rf node_modules
                    npm start
                    Yap, the installation has failed several times. I’ll try re-install as your direction.
                    regards,
                    Slamet PS
                    • slametpsS Offline
                      slametps @sdetweil
                      so lets do this
                      rm -rf node_modules
                      npm start
                      I got the following error when execute
                      pi@raspberrypi:~/MagicMirror $ npm install --only=prod
                      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                      npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                      npm ERR! code EINTEGRITY
                      npm ERR! errno EINTEGRITY
                      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/chai: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                      npm ERR!     /home/pi/.npm/_logs/2021-03-07T13_53_31_822Z-debug.log
                      regards,
                      Slamet PS
                        sdetweil @slametps
                        @slametps fun…
                        do
                        cd ~
                        sudo rm -rf  .npm
                        rm -rf MagicMirror
                        note the dot in front of npm
                        then run the install script again.
                        • slametpsS Offline
                          slametps @sdetweil
                          @slametps fun…
                          do
                          cd ~
                          sudo rm -rf  .npm
                          rm -rf MagicMirror
                          It works like a charm. Thx a lot @sdetweil .
                          regards,
                          Slamet PS
