    Got error when run MM 2.14.0
    11 Posts 2 Posters 4.5k Views 2 Watching
    • slametpsS Offline
      slametps @slametps
      @slametps said in Got error when run MM 2.14.0:
      @sdetweil : no, it is a fresh install.
      Here is the link to install.log
      The raspberry is also a fresh install, I created the disk using Raspberry Pi Imager.
      regards,
      Slamet PS
        sdetweil @slametps
        @slametps ok, don’t know what happened… looks like u ran install 5 separate times…
        so lets do this
        rm  package-lock.json
        rm -rf node_modules
        npm install --only=prod
        then try to start MM,
        npm start
        slametpsS 2 Replies Last reply Reply Quote 0
        • slametpsS Offline
          slametps @sdetweil
          @sdetweil said in Got error when run MM 2.14.0:
          so lets do this
          rm -rf node_modules
          npm start
          Yap, the installation has failed several times. I’ll try re-install as your direction.
          regards,
          Slamet PS
          • slametpsS Offline
            slametps @sdetweil
            so lets do this
            rm -rf node_modules
            npm start
            I got the following error when execute
            pi@raspberrypi:~/MagicMirror $ npm install --only=prod
            npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
            npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
            npm ERR! code EINTEGRITY
            npm ERR! errno EINTEGRITY
            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/chai: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
            npm ERR!     /home/pi/.npm/_logs/2021-03-07T13_53_31_822Z-debug.log
            regards,
            Slamet PS
              sdetweil @slametps
              @slametps fun…
              do
              cd ~
              sudo rm -rf  .npm
              rm -rf MagicMirror
              note the dot in front of npm
              then run the install script again.
              slametpsS 1 Reply Last reply Reply Quote 0
              • slametpsS Offline
                slametps @sdetweil
                @slametps fun…
                do
                cd ~
                sudo rm -rf  .npm
                rm -rf MagicMirror
                It works like a charm. Thx a lot @sdetweil .
                regards,
                Slamet PS
