    Got error when run MM 2.14.0
    11 Posts 2 Posters 4.4k Views 2 Watching
      sdetweil @slametps
      @slametps to fix the run-start.sh problem do
      cd  ~/MagicMirror
      curl  -sL  https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh > run-start.sh
        sdetweil @slametps
        @slametps also, did u edit the config.js and change ipWhitelist at all?
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @sdetweil
          @sdetweil : no, it is a fresh install.
          Here is the link to install.log
          regards,
          Slamet PS
          • slametpsS Offline
            slametps @slametps
            @slametps said in Got error when run MM 2.14.0:
            The raspberry is also a fresh install, I created the disk using Raspberry Pi Imager.
            regards,
            Slamet PS
              sdetweil @slametps
              @slametps ok, don’t know what happened… looks like u ran install 5 separate times…
              so lets do this
              rm  package-lock.json
              rm -rf node_modules
              npm install --only=prod
              then try to start MM,
              npm start
              slametpsS 2 Replies Last reply Reply Quote 0
              • slametpsS Offline
                slametps @sdetweil
                @sdetweil said in Got error when run MM 2.14.0:
                so lets do this
                rm -rf node_modules
                npm start
                Yap, the installation has failed several times. I’ll try re-install as your direction.
                regards,
                Slamet PS
                • slametpsS Offline
                  slametps @sdetweil
                  so lets do this
                  rm -rf node_modules
                  npm start
                  I got the following error when execute
                  pi@raspberrypi:~/MagicMirror $ npm install --only=prod
                  npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                  npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                  npm ERR! code EINTEGRITY
                  npm ERR! errno EINTEGRITY
                  npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/chai: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                  npm ERR!     /home/pi/.npm/_logs/2021-03-07T13_53_31_822Z-debug.log
                  regards,
                  Slamet PS
                    sdetweil @slametps
                    @slametps fun…
                    do
                    cd ~
                    sudo rm -rf  .npm
                    rm -rf MagicMirror
                    note the dot in front of npm
                    then run the install script again.
                    • slametpsS Offline
                      slametps @sdetweil
                      @slametps fun…
                      do
                      cd ~
                      sudo rm -rf  .npm
                      rm -rf MagicMirror
                      It works like a charm. Thx a lot @sdetweil .
                      regards,
                      Slamet PS
