    Head first developing MM module for extreme beginners
    27 Posts 9 Posters 32.2k Views 12 Watching
      sdetweil @Schmaniel
      @Schmaniel ctrl-r to reload the screen
      Reply Quote 2
      • N
        nrayever @sdetweil
        @sdetweil … ok.
        D 1 Reply Last reply
          Dobi @nrayever
          Hey guys,
          I’m quite new in developing an own module. I was able to change exiting modules on my magic mirror but now I wanted to create my own module, but I’m not able to get socket communication between my “main” module an the “helper-function”
          I uploaded my module here:
          https://github.com/Dobherrmann/MMM_Testmodul.git
          my Module looks like this on my magic mirror:
          maybe someone can find my mistake(s).
          BR
            sdetweil @Dobi
            @dobi two things
            when the DomObject Created method is called, its POSSIBLE that the elements are not yet accessible… so your code fails as the document.getElementbyID returns null…
            second, do you have a position: set in the module def in config.js?
            third and MOST important
            the module NAME must match the folder name AND the filename and the register in the file…
            so, the filename is MMM-cookbook.js
            therefore ALL the things must be called MMM-cookbook
            git clone will name the folder the name of the github repo
            (unless u add an extra part to git clone repo_url output_folder_name)
            I fixed all those and the module displays the countdown/up each second
              Dobi @sdetweil
              @sdetweil ahh thank you for these information I will give it a try.
                Dobi
                @sdetweil I gave it a try but without differences :(
                I made a new git repo : https://github.com/Dobherrmann/MMM-cookbook.git
                Now there I should have the same name in the repo like my module.
                my config. js looks like this (I gave it a position):
                      module: "MMM-cookbook",
                      position: "middle_center",
                        header: "My Cookbook",
                        foo: "I'm the King of the world!"
                I started to debug “my code” a little bit and I found this when I want to send a socket notification:
                self.sendSocketNotification("DO_YOUR_JOB", this.count);
                					console.log("Notfication", this.sendSocketNotification("DO_YOUR_JOB", this.count))
                					this.subElementUp.innerHTML = "Count UP:" + this.count
                On my console i get the feedback that “this.sendSocketNotification(“DO_YOUR_JOB”, this.count” is undefined. It looks like that this function is unkown.
                  sdetweil @Dobi
                  @dobi u are inside a callback. change the ‘this’ to ‘self’ like the self.sendSocketNotification
                  ‘this’ is always tricky. depends on the context, and some of the programming idioms used
                  that’s why we typically see
                  var self = this;
                  at the beginning of functions that have callbacks or .then() used inside
                    Dobi @sdetweil
                    @sdetweil ok, but it dosen’t change something.
                    notificationReceived: function (notification, payload, sender) {
                    		self = this;
                    		switch (notification) {
                    			case "DOM_OBJECTS_CREATED":
                    				var timer = setInterval(() => {
                    					//this.updateDom()
                    					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", this.count))
                    					this.count++
                    				}, 1000)
                    				break
                    Now i could post a picture of my console
                    S 2 Replies Last reply
                      sdetweil @Dobi
                      @dobi show the source code page. u had to fix both counters
                      sources tab, modules, mmm-cookbook, mmm-cookbook.js
                        sdetweil @Dobi
                        @dobi
                        but u didn’t change this.count to self.count
                        in all the places
                          Dobi @sdetweil
                          @sdetweil I replaced all this. … calls to self. … but I don’t get a change. Is there a way that I can check to check that I can check that the function is loaded correctly from the kernal?
                            sdetweil @Dobi
                            @dobi view the source in the dev window
                            what u showed above is not changed
                              Dobi @sdetweil
                              sorry I only updated it on github
                              		var self = this;
                              					//this.updateDom()
                              					self.sendSocketNotification("DO_YOUR_JOB", self.count);
                              					console.log(`self.sendSocketNotification("DO_YOUR_JOB", this.count)`, self.sendSocketNotification("DO_YOUR_JOB", self.count))
                              					self.subElementUp.innerHTML = "Count UP:" + self.count
                              					self.count++
                              				}, 1000)
                              				break
                                sdetweil @Dobi
                                @dobi and in the console.log too
                                  Dobi @sdetweil
                                  @sdetweil Hey sorry for my quite late response. But I wanted to tell you that I found my error it was quite stupid. I had to restart my raspi. After a restart the node_helper worked fine :)
                                  I wrote my first module.
                                  Thanks for your patient
                                  S cowboysdudeC 2 Replies Last reply
                                  Reply Quote 2
                                    sdetweil @Dobi
                                    @dobi glad you found it… so much fun!!
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Dobi
                                      @dobi See you can do it! Great job and glad that it all worked out for you! :) This is what this project is about…learning.
                                      NOW you can make your mirror your own by showing information that you want and/or need to see…
                                        riich
                                        Anyone have an idea on how to display an image instead of a line. I downloaded a jpeg image of a dog and I would like to display that instead of
