    Display Control Board
    hardware
    5 Posts 3 Posters 2.2k Views 3 Watching
      muggerrudd
      I pulled a display off a MS surface.
      Display PN: VVX11F037N00
      Resolution: 1920x1280
      Voltage: 3.3
      Signal: MIPI (4 data lanes) , 40 pins Connector
      Panel Type: a-Si TFT-LCD , LCM
      https://www.panelook.com/VVX11F037N00_Panasonic_11_LCM_overview_25444.html
      I’ve done some googling without any clear answer.
      What display controller board do I need?
        muggerrudd @muggerrudd
        @muggerrudd
        The cable coming from the assembly is a 35pin. Im assuming this is proprietary since the display has the screen and touch panel combined to a pcb.
          MadScientist @muggerrudd
          @muggerrudd
          Hmm, I have no experience with those displays. All I can see from your link is that it has a MIPI interface, instead of LVDS for regular LCD panels.
          I did some 3 minutes google research and found mainly LCD+MIPI controller sets. On AliExpress I found single MIPI controllers but I don’t know what to look for when buying those.
          Please let us know if you find out more. I think that could be interesting for others (and me).
            muggerrudd @MadScientist
            @madscientist
            Here is an image of the back of the display.
            The ribbon cable is 35pin.
            • A
              AveDalang
              Hi…Some more up to date Samsung LED-LCDs and LCDs with 240Hz processor have separate tests for FRC (movement upconverter/T-con) and principle board from administration menu, yet no entrance if TV will not catalyst and menus aren’t usable.
