    Help please!!
    63 Posts 4 Posters 39.7k Views 4 Watching
      barlouka @sdetweil
      @sdetweil also command not found
        sdetweil @barlouka
        @barlouka ok, go to the module folder and do git pull
        then do npm install again
        then test qrcp --help
        I 1 Reply Last reply
        • I
          innovation @sdetweil
          @sdetweil It still shows command not found
            sdetweil @innovation
            @innovation yeh, crazy… how it ever worked before I don’t know
            ONE more time git pull, npm install
            • I
              @sdetweil Haha sure! Just to clarify in
              ‘-/MagicMirror/modules/uploadPics’ folder in the terminal right?
                @innovation but the module wants RELATIVE to it… NOT absolute
                SO, …/MMM-ImagesPhotos/upload
                … means back up one level
                and, if you are using the MMM-ImagesPhotos module to display images, then the uploadPics dest: default is …/MMM-ImagesPhotos/upload
                from the readme
                	dest:  "..", // relative path to module showing images, place to put new images
                            // for MMM-ImagesPhotos dest is (the default)
                	//  ../modules/MMMM-ImagesPhotos/uploads
                • I
                  @sdetweil Yes, it still is showing undefined though
                    @innovation
                    is this on a pi4? I see a problem with the qrcp it wants to know which adapter to run on, wifi or ethernet… and its parms aren;t working… I tried on all kinds of machines with one adapter… weird…
                    if pi4 open terminal do qrcp config
                    and basically hit enter til it ends
                    then try mm again
                    S I 2 Replies Last reply
                      install setup fixed
                      please git pull
                      and then npm install again
                      B 1 Reply Last reply
                      • I
                        @sdetweil No, it is a Pi 3B
                          barlouka @sdetweil
                          @sdetweil Thank you. It works perfect. Fantastic module.
                            I added some more updates, the app that corrects the image orientation runs only on what u upload now, not ALL the images int he folder… (could be hundreds or thousands)…
                            debug:true to turn on messages from node helper and module (false by default)
                            took out other dead code
                            edit: to add the npm install
                            git pull in the module folder to get the latest, npm install and then restart MM
                            • I
                              • I
                                @sdetweil Hello! Yes I can see the QR code on the display. However, when I scan it - this is what its showing me
                                What does this mean?
                                  @innovation did you git pull and npm install the latest
                                  the postinstall script is supposed to fix that
                                  • I
                                    It says it’s up to date
                                      @innovation and then u did npm install
                                      • I
                                        innovation
                                        @sdetweil Yes
                                          @innovation can u open a terminal window and do
                                          qrcp
                                          and look in the module folder for qrcp.json
                                          • I
                                            @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                                            • 2 / 4
