    Help please!!
    63 Posts 4 Posters 39.7k Views 4 Watching
    • I
      innovation @sdetweil
      @sdetweil It still shows command not found
        sdetweil @innovation
        @innovation yeh, crazy… how it ever worked before I don’t know
        ONE more time git pull, npm install
        I 1 Reply Last reply
        • I
          @sdetweil Haha sure! Just to clarify in
          ‘-/MagicMirror/modules/uploadPics’ folder in the terminal right?
            @innovation but the module wants RELATIVE to it… NOT absolute
            SO, …/MMM-ImagesPhotos/upload
            … means back up one level
            and, if you are using the MMM-ImagesPhotos module to display images, then the uploadPics dest: default is …/MMM-ImagesPhotos/upload
            from the readme
            	dest:  "..", // relative path to module showing images, place to put new images
                        // for MMM-ImagesPhotos dest is (the default)
            	//  ../modules/MMMM-ImagesPhotos/uploads
            • I
              @sdetweil Yes, it still is showing undefined though
                @innovation
                is this on a pi4? I see a problem with the qrcp it wants to know which adapter to run on, wifi or ethernet… and its parms aren;t working… I tried on all kinds of machines with one adapter… weird…
                if pi4 open terminal do qrcp config
                and basically hit enter til it ends
                then try mm again
                S I 2 Replies Last reply
                  install setup fixed
                  please git pull
                  and then npm install again
                  B 1 Reply Last reply
                  • I
                    @sdetweil No, it is a Pi 3B
                      barlouka @sdetweil
                      @sdetweil Thank you. It works perfect. Fantastic module.
                        I added some more updates, the app that corrects the image orientation runs only on what u upload now, not ALL the images int he folder… (could be hundreds or thousands)…
                        debug:true to turn on messages from node helper and module (false by default)
                        took out other dead code
                        edit: to add the npm install
                        git pull in the module folder to get the latest, npm install and then restart MM
                        • I
                          • I
                            @sdetweil Hello! Yes I can see the QR code on the display. However, when I scan it - this is what its showing me
                            What does this mean?
                              @innovation did you git pull and npm install the latest
                              the postinstall script is supposed to fix that
                              • I
                                It says it’s up to date
                                  @innovation and then u did npm install
                                  • I
                                    innovation
                                    @sdetweil Yes
                                      @innovation can u open a terminal window and do
                                      qrcp
                                      and look in the module folder for qrcp.json
                                      • I
                                        @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                                          @innovation yes
                                          • I
                                            @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
                                            These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
                                            Use man -k' or info’ to find out more about commands not in this list.
                                            A star (*) next to a name means that the command is disabled.
                                            job_spec [&] history [-c] [-d offset] [n] or history -anrw >
                                            (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
                                            . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
                                            : kill [-s sigspec | -n signum | -sigspec] pid |>
                                            [ arg… ] let arg [arg …]
                                            [[ expression ]] local [option] name[=value] …
                                            alias [-p] [name[=value] … ] logout [n]
                                            bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
                                            bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
                                            break [n] printf [-v var] format [arguments]
                                            builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
                                            caller [expr] pwd [-LP]
                                            case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
                                            cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
                                            command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
                                            compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
                                            complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
                                            compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
                                            continue [n] shift [n]
                                            coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
                                            declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
                                            dirs [-clpv] [+N] [-N] suspend [-f]
                                            disown [-h] [-ar] [jobspec … | pid …] test [expr]
                                            echo [-neE] [arg …] time [-p] pipeline
                                            enable [-a] [-dnps] [-f filename] [name …] times
                                            eval [arg …] trap [-lp] [[arg] signal_spec …]
                                            exec [-cl] [-a name] [command [arguments …]] > true
                                            exit [n] type [-afptP] name [name …]
                                            export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
                                            false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
                                            fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
                                            fg [job_spec] unalias [-a] name [name …]
                                            for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
                                            for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
                                            function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
                                            getopts optstring name [arg] wait [-fn] [id …]
                                            hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
                                            help [-dms] [pattern …] { COMMANDS ; }
                                            This is what it says
                                            • 2 / 4
