    Help please!!
    63 Posts 4 Posters 37.0k Views 4 Watching
      sdetweil @barlouka
      @barlouka ok, go to the module folder and do git pull
      then do npm install again
      then test qrcp --help
      • I Offline
        innovation @sdetweil
        @sdetweil It still shows command not found
          sdetweil @innovation
          @innovation yeh, crazy… how it ever worked before I don’t know
          ONE more time git pull, npm install
          • I Offline
            @sdetweil Haha sure! Just to clarify in
            ‘-/MagicMirror/modules/uploadPics’ folder in the terminal right?
              @innovation but the module wants RELATIVE to it… NOT absolute
              SO, …/MMM-ImagesPhotos/upload
              … means back up one level
              and, if you are using the MMM-ImagesPhotos module to display images, then the uploadPics dest: default is …/MMM-ImagesPhotos/upload
              from the readme
              	dest:  "..", // relative path to module showing images, place to put new images
                          // for MMM-ImagesPhotos dest is (the default)
              	//  ../modules/MMMM-ImagesPhotos/uploads
              • I Offline
                @sdetweil Yes, it still is showing undefined though
                  @innovation
                  is this on a pi4? I see a problem with the qrcp it wants to know which adapter to run on, wifi or ethernet… and its parms aren;t working… I tried on all kinds of machines with one adapter… weird…
                  if pi4 open terminal do qrcp config
                  and basically hit enter til it ends
                  then try mm again
                  S I 2 Replies Last reply Reply Quote 0
                    install setup fixed
                    please git pull
                    and then npm install again
                    • I Offline
                      @sdetweil No, it is a Pi 3B
                        barlouka @sdetweil
                        @sdetweil Thank you. It works perfect. Fantastic module.
                          I added some more updates, the app that corrects the image orientation runs only on what u upload now, not ALL the images int he folder… (could be hundreds or thousands)…
                          debug:true to turn on messages from node helper and module (false by default)
                          took out other dead code
                          edit: to add the npm install
                          git pull in the module folder to get the latest, npm install and then restart MM
                          • I Offline
                            • I Offline
                              @sdetweil Hello! Yes I can see the QR code on the display. However, when I scan it - this is what its showing me
                              What does this mean?
                                @innovation did you git pull and npm install the latest
                                the postinstall script is supposed to fix that
                                • I Offline
                                  It says it’s up to date
                                    @innovation and then u did npm install
                                    • I Offline
                                      innovation
                                      @sdetweil Yes
                                        @innovation can u open a terminal window and do
                                        qrcp
                                        and look in the module folder for qrcp.json
                                        • I Offline
                                          @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                                            @innovation yes
                                            • 2 / 4
