    Help please!!
    63 Posts 4 Posters 38.8k Views 4 Watching
      sdetweil @innovation
      @innovation and then u did npm install
      • I
        innovation
        @sdetweil Yes
          @innovation can u open a terminal window and do
          qrcp
          and look in the module folder for qrcp.json
          I 1 Reply Last reply
          • I
            innovation @sdetweil
            @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
              @innovation yes
              • I
                @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
                These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
                Use man -k' or info’ to find out more about commands not in this list.
                A star (*) next to a name means that the command is disabled.
                job_spec [&] history [-c] [-d offset] [n] or history -anrw >
                (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
                . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
                : kill [-s sigspec | -n signum | -sigspec] pid |>
                [ arg… ] let arg [arg …]
                [[ expression ]] local [option] name[=value] …
                alias [-p] [name[=value] … ] logout [n]
                bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
                bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
                break [n] printf [-v var] format [arguments]
                builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
                caller [expr] pwd [-LP]
                case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
                cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
                command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
                compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
                complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
                compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
                continue [n] shift [n]
                coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
                declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
                dirs [-clpv] [+N] [-N] suspend [-f]
                disown [-h] [-ar] [jobspec … | pid …] test [expr]
                echo [-neE] [arg …] time [-p] pipeline
                enable [-a] [-dnps] [-f filename] [name …] times
                eval [arg …] trap [-lp] [[arg] signal_spec …]
                exec [-cl] [-a name] [command [arguments …]] > true
                exit [n] type [-afptP] name [name …]
                export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
                false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
                fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
                fg [job_spec] unalias [-a] name [name …]
                for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
                for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
                function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
                getopts optstring name [arg] wait [-fn] [id …]
                hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
                help [-dms] [pattern …] { COMMANDS ; }
                This is what it says
                  @innovation what did u type??
                  qrcp
                  should have replied
                  sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
                  Error: requires at least 1 arg(s), only received 0
                  Run `qrcp help` for help.
                  anf then, if the file was present
                  ls qrcp.json
                  should have replied
                  sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
                  qrcp.json
                  • I
                    pi@smart:~ $ qrcp
                    Run qrcp help for help.
                      @innovation and for the file?
                      • I
                        pi@smart:~ $ ls qrcp.json
                        ls: cannot access ‘qrcp.json’: No such file or directory
                        pi@smart:~ $
                          @innovation ok, then do these two commands
                          ip link show
                          iwconfig
                          show the results
                          mine look like this
                          sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
                          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
                              link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                          9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
                              link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
                          sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
                          wlp1s0    IEEE 802.11  ESSID:"fubar"
                                    Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                                    Bit Rate=650 Mb/s   Tx-Power=22 dBm
                                    Retry short limit:7   RTS thr:off   Fragment thr:off
                                    Power Management:on
                                    Link Quality=70/70  Signal level=-34 dBm
                                    Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                                    Tx excessive retries:0  Invalid misc:52   Missed beacon:0
                          lo        no wireless extensions.
                          I 2 Replies Last reply
                          • I
                            • I
                              pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
                              2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
                              link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
                              3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
                              link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
                              pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
                              eth0 no wireless extensions.
                              wlan0 IEEE 802.11 ESSID:“ssk3”
                              Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
                              Bit Rate=24 Mb/s Tx-Power=31 dBm
                              Power Management:on
                              Link Quality=42/70 Signal level=-68 dBm
                              Tx excessive retries:10 Invalid misc:0 Missed beacon:0
                                @innovation ok,
                                postinstall should be 43 lines long
                                if so do this
                                ./postinstall
                                the check for qrcp.json again
                                • I
                                  @sdetweil Yes the file is there now
                                  pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                                  qrcp.json
                                    @innovation ok, start mm
                                    • I
                                      @sdetweil I am getting the same “default message if none supplied in the config.js”
                                        @innovation weird
                                        ok, add
                                        debug: true,
                                        to the module definition
                                        and then do
                                        npm start >somefile
                                        once mm comes up u can stop it and then we can look at somefile
                                        • I
                                          @sdetweil npm start >somefile
                                          npm ERR! missing script: start
                                          npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
                                          Yes, the program started then I ended it
                                            @innovation from the magicmirror folder please
                                            • 2 / 4
