    Help please!!
    63 Posts 4 Posters 37.6k Views 4 Watching
      sdetweil @innovation
      @innovation what did u type??
      qrcp
      should have replied
      sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
      Error: requires at least 1 arg(s), only received 0
      Run `qrcp help` for help.
      anf then, if the file was present
      ls qrcp.json
      should have replied
      sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
      qrcp.json
      • I
        innovation @sdetweil
        pi@smart:~ $ qrcp
        Run qrcp help for help.
          @innovation and for the file?
          • I
            pi@smart:~ $ ls qrcp.json
            ls: cannot access ‘qrcp.json’: No such file or directory
            pi@smart:~ $
              @innovation ok, then do these two commands
              ip link show
              iwconfig
              show the results
              mine look like this
              sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
              9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
                  link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
              sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
              wlp1s0    IEEE 802.11  ESSID:"fubar"
                        Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                        Bit Rate=650 Mb/s   Tx-Power=22 dBm
                        Retry short limit:7   RTS thr:off   Fragment thr:off
                        Power Management:on
                        Link Quality=70/70  Signal level=-34 dBm
                        Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                        Tx excessive retries:0  Invalid misc:52   Missed beacon:0
              lo        no wireless extensions.
              I 2 Replies Last reply Reply Quote 0
              • I
                • I
                  pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
                  2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
                  link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
                  3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
                  link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
                  pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
                  eth0 no wireless extensions.
                  wlan0 IEEE 802.11 ESSID:“ssk3”
                  Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
                  Bit Rate=24 Mb/s Tx-Power=31 dBm
                  Power Management:on
                  Link Quality=42/70 Signal level=-68 dBm
                  Tx excessive retries:10 Invalid misc:0 Missed beacon:0
                    @innovation ok,
                    postinstall should be 43 lines long
                    if so do this
                    ./postinstall
                    the check for qrcp.json again
                    • I
                      @sdetweil Yes the file is there now
                      pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                      qrcp.json
                        @innovation ok, start mm
                        • I
                          @sdetweil I am getting the same “default message if none supplied in the config.js”
                            @innovation weird
                            ok, add
                            debug: true,
                            to the module definition
                            and then do
                            npm start >somefile
                            once mm comes up u can stop it and then we can look at somefile
                            • I
                              @sdetweil npm start >somefile
                              npm ERR! missing script: start
                              npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
                              Yes, the program started then I ended it
                                @innovation from the magicmirror folder please
                                • I
                                  @sdetweil Yes it opened. Where is the somefile?
                                    @innovation in the magicmirror folder
                                    > means put all the terminal window content of the pgm into the file
                                    (same as for windows)
                                    • I
                                      @sdetweil Nothing shows up in the terminal when I run in though
                                        @innovation don’t understand, mm puts out messages
                                        looks like this
                                        > magicmirror@2.14.0 start /home/sam/MagicMirror
                                        [26.03.2021 11:17.39.334] [LOG]   Starting MagicMirror: v2.14.0
                                        [26.03.2021 11:17.39.338] [LOG]   Loading config ...
                                        [26.03.2021 11:17.39.343] [LOG]   Loading module helpers ...
                                        [26.03.2021 11:17.39.345] [LOG]   No helper found for module: alert.
                                        [26.03.2021 11:17.39.483] [LOG]   Initializing new module helper ...
                                        [26.03.2021 11:17.39.483] [LOG]   Module helper loaded: updatenotification
                                        [26.03.2021 11:17.39.484] [LOG]   No helper found for module: clock.
                                        [26.03.2021 11:17.39.843] [LOG]   Initializing new module helper ...
                                        [26.03.2021 11:17.39.843] [LOG]   Module helper loaded: calendar
                                        [26.03.2021 11:17.39.844] [LOG]   No helper found for module: currentweather.
                                        [26.03.2021 11:17.39.845] [LOG]   No helper found for module: weatherforecast.
                                        [26.03.2021 11:17.39.865] [LOG]   Initializing new module helper ...
                                        [26.03.2021 11:17.39.866] [LOG]   Module helper loaded: newsfeed
                                        [26.03.2021 11:17.39.867] [LOG]   init module helper undefinedundefined
                                        [26.03.2021 11:17.39.868] [LOG]   Module helper loaded: uploadPics
                                          @innovation if u do the > symbol, then ALL the output goes to the file
                                          • I
                                            @sdetweil > magicmirror@2.13.0 start /home/pi/MagicMirror
                                            [2021-03-26 22:24:56.461] [LOG] Starting MagicMirror: v2.13.0
                                            [2021-03-26 22:24:56.519] [LOG] Loading config …
                                            [2021-03-26 22:24:56.541] [LOG] Loading module helpers …
                                            [2021-03-26 22:24:56.546] [LOG] No helper found for module: compliments.
                                            [2021-03-26 22:24:56.556] [LOG] No helper found for module: MMM-CSSBackgrounds.
                                            [2021-03-26 22:24:56.586] [LOG] Module helper loaded: uploadPics
                                            [2021-03-26 22:24:56.588] [LOG] All module helpers loaded.
                                            [2021-03-26 22:24:57.103] [LOG] Starting server on port 8080 …
                                            [2021-03-26 22:24:57.164] [LOG] Server started …
                                            [2021-03-26 22:24:57.166] [LOG] Connecting socket for: uploadPics
                                            [2021-03-26 22:24:57.168] [LOG] Sockets connected & modules started …
                                            [2021-03-26 22:24:58.047] [LOG] Launching application.
                                            ^C[2021-03-26 22:26:14.188] [LOG] Shutting down server…
                                            • 3 / 4
