    Help please!!
    63 Posts 4 Posters 37.6k Views 4 Watching
      sdetweil @innovation
      @innovation ok,
      postinstall should be 43 lines long
      if so do this
      ./postinstall
      the check for qrcp.json again
      • I
        innovation @sdetweil
        @sdetweil Yes the file is there now
        pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
        qrcp.json
          @innovation ok, start mm
          • I
            @sdetweil I am getting the same “default message if none supplied in the config.js”
              @innovation weird
              ok, add
              debug: true,
              to the module definition
              and then do
              npm start >somefile
              once mm comes up u can stop it and then we can look at somefile
              • I
                @sdetweil npm start >somefile
                npm ERR! missing script: start
                npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
                Yes, the program started then I ended it
                  @innovation from the magicmirror folder please
                  • I
                    @sdetweil Yes it opened. Where is the somefile?
                      @innovation in the magicmirror folder
                      > means put all the terminal window content of the pgm into the file
                      (same as for windows)
                      • I
                        @sdetweil Nothing shows up in the terminal when I run in though
                          @innovation don’t understand, mm puts out messages
                          looks like this
                          > magicmirror@2.14.0 start /home/sam/MagicMirror
                          [26.03.2021 11:17.39.334] [LOG]   Starting MagicMirror: v2.14.0
                          [26.03.2021 11:17.39.338] [LOG]   Loading config ...
                          [26.03.2021 11:17.39.343] [LOG]   Loading module helpers ...
                          [26.03.2021 11:17.39.345] [LOG]   No helper found for module: alert.
                          [26.03.2021 11:17.39.483] [LOG]   Initializing new module helper ...
                          [26.03.2021 11:17.39.483] [LOG]   Module helper loaded: updatenotification
                          [26.03.2021 11:17.39.484] [LOG]   No helper found for module: clock.
                          [26.03.2021 11:17.39.843] [LOG]   Initializing new module helper ...
                          [26.03.2021 11:17.39.843] [LOG]   Module helper loaded: calendar
                          [26.03.2021 11:17.39.844] [LOG]   No helper found for module: currentweather.
                          [26.03.2021 11:17.39.845] [LOG]   No helper found for module: weatherforecast.
                          [26.03.2021 11:17.39.865] [LOG]   Initializing new module helper ...
                          [26.03.2021 11:17.39.866] [LOG]   Module helper loaded: newsfeed
                          [26.03.2021 11:17.39.867] [LOG]   init module helper undefinedundefined
                          [26.03.2021 11:17.39.868] [LOG]   Module helper loaded: uploadPics
                            @innovation if u do the > symbol, then ALL the output goes to the file
                            • I
                              @sdetweil > magicmirror@2.13.0 start /home/pi/MagicMirror
                              [2021-03-26 22:24:56.461] [LOG] Starting MagicMirror: v2.13.0
                              [2021-03-26 22:24:56.519] [LOG] Loading config …
                              [2021-03-26 22:24:56.541] [LOG] Loading module helpers …
                              [2021-03-26 22:24:56.546] [LOG] No helper found for module: compliments.
                              [2021-03-26 22:24:56.556] [LOG] No helper found for module: MMM-CSSBackgrounds.
                              [2021-03-26 22:24:56.586] [LOG] Module helper loaded: uploadPics
                              [2021-03-26 22:24:56.588] [LOG] All module helpers loaded.
                              [2021-03-26 22:24:57.103] [LOG] Starting server on port 8080 …
                              [2021-03-26 22:24:57.164] [LOG] Server started …
                              [2021-03-26 22:24:57.166] [LOG] Connecting socket for: uploadPics
                              [2021-03-26 22:24:57.168] [LOG] Sockets connected & modules started …
                              [2021-03-26 22:24:58.047] [LOG] Launching application.
                              ^C[2021-03-26 22:26:14.188] [LOG] Shutting down server…
                                @innovation did u add debug: true to the uploadPics module config section
                                                        module:"uploadPics",
                                                        disabled:false,
                                                        position:"bottom_left",
                                                        config:{
        dest : '../modules/MMM-ImagesPhotos/uploads',
        debug:true
                                • I
                                  @sdetweil Sorry, put it in the wrong place
                                  [2021-03-26 22:34:16.943] [LOG] Starting MagicMirror: v2.13.0
                                  [2021-03-26 22:34:17.001] [LOG] Loading config …
                                  [2021-03-26 22:34:17.016] [LOG] Loading module helpers …
                                  [2021-03-26 22:34:17.020] [LOG] No helper found for module: compliments.
                                  [2021-03-26 22:34:17.026] [LOG] No helper found for module: MMM-CSSBackgrounds.
                                  [2021-03-26 22:34:17.045] [LOG] Module helper loaded: uploadPics
                                  [2021-03-26 22:34:17.046] [LOG] All module helpers loaded.
                                  [2021-03-26 22:34:17.520] [LOG] Starting server on port 8080 …
                                  [2021-03-26 22:34:17.560] [LOG] Server started …
                                  [2021-03-26 22:34:17.562] [LOG] Connecting socket for: uploadPics
                                  [2021-03-26 22:34:17.564] [LOG] Sockets connected & modules started …
                                  [2021-03-26 22:34:18.464] [LOG] Launching application.
                                  [2021-03-26 22:34:24.895] [LOG] uploadPics received a socket notification: CONFIG - Payload: [object Object]
                                  [2021-03-26 22:34:24.898] [LOG] p=/home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads
                                  [2021-03-26 22:34:26.239] [LOG] error=Error: stat /home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads: no such file or directory
                                  Run qrcp help for help.
                                  ^C[2021-03-26 22:34:38.105] [LOG] Shutting down server…
                                  [2021-03-26 22:34:38.107] [LOG] Stopping module helper: uploadPics
                                    @innovation said in Help please!!:
                                    where are the uploaded pics supposed to go?
                                    that folder doesn’t exist…
                                    • I
                                      @sdetweil But there is a folder in
                                      /home/pi/MagicMirror/modules/MMM-ImagesPhotos/uploads
                                        @innovation ‘’/MMMM’
                                        typo in the dest config… 4 M’s instead of 3
                                        • I
                                          @sdetweil Yes it works! Thank you so much for this. I really appreciate it
                                            @innovation glad u got it… i changed the message to say check the config
                                            and also allowed the error message to pass thru even if not in debug mode… thanks for your patience
                                            • 3 / 4
