    Help please!!
    63 Posts 4 Posters 39.7k Views 4 Watching
    • I
      innovation @sdetweil
      pi@smart:~ $ ls qrcp.json
      ls: cannot access ‘qrcp.json’: No such file or directory
      pi@smart:~ $
        sdetweil @innovation
        @innovation ok, then do these two commands
        ip link show
        iwconfig
        show the results
        mine look like this
        sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
            link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
            link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
        sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
        wlp1s0    IEEE 802.11  ESSID:"fubar"
                  Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                  Bit Rate=650 Mb/s   Tx-Power=22 dBm
                  Retry short limit:7   RTS thr:off   Fragment thr:off
                  Power Management:on
                  Link Quality=70/70  Signal level=-34 dBm
                  Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                  Tx excessive retries:0  Invalid misc:52   Missed beacon:0
        lo        no wireless extensions.
        I 2 Replies Last reply
        • I
          • I
            pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
            2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
            link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
            3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
            link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
            pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
            eth0 no wireless extensions.
            wlan0 IEEE 802.11 ESSID:“ssk3”
            Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
            Bit Rate=24 Mb/s Tx-Power=31 dBm
            Power Management:on
            Link Quality=42/70 Signal level=-68 dBm
            Tx excessive retries:10 Invalid misc:0 Missed beacon:0
              @innovation ok,
              postinstall should be 43 lines long
              if so do this
              ./postinstall
              the check for qrcp.json again
              I 1 Reply Last reply
              • I
                @sdetweil Yes the file is there now
                pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                qrcp.json
                  @innovation ok, start mm
                  • I
                    @sdetweil I am getting the same “default message if none supplied in the config.js”
                      @innovation weird
                      ok, add
                      debug: true,
                      to the module definition
                      and then do
                      npm start >somefile
                      once mm comes up u can stop it and then we can look at somefile
                      • I
                        @sdetweil npm start >somefile
                        npm ERR! missing script: start
                        npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
                        Yes, the program started then I ended it
                          @innovation from the magicmirror folder please
                          • I
                            @sdetweil Yes it opened. Where is the somefile?
                              @innovation in the magicmirror folder
                              > means put all the terminal window content of the pgm into the file
                              (same as for windows)
                              • I
                                @sdetweil Nothing shows up in the terminal when I run in though
                                S 2 Replies Last reply
                                  @innovation don’t understand, mm puts out messages
                                  looks like this
                                  > magicmirror@2.14.0 start /home/sam/MagicMirror
                                  [26.03.2021 11:17.39.334] [LOG]   Starting MagicMirror: v2.14.0
                                  [26.03.2021 11:17.39.338] [LOG]   Loading config ...
                                  [26.03.2021 11:17.39.343] [LOG]   Loading module helpers ...
                                  [26.03.2021 11:17.39.345] [LOG]   No helper found for module: alert.
                                  [26.03.2021 11:17.39.483] [LOG]   Initializing new module helper ...
                                  [26.03.2021 11:17.39.483] [LOG]   Module helper loaded: updatenotification
                                  [26.03.2021 11:17.39.484] [LOG]   No helper found for module: clock.
                                  [26.03.2021 11:17.39.843] [LOG]   Initializing new module helper ...
                                  [26.03.2021 11:17.39.843] [LOG]   Module helper loaded: calendar
                                  [26.03.2021 11:17.39.844] [LOG]   No helper found for module: currentweather.
                                  [26.03.2021 11:17.39.845] [LOG]   No helper found for module: weatherforecast.
                                  [26.03.2021 11:17.39.865] [LOG]   Initializing new module helper ...
                                  [26.03.2021 11:17.39.866] [LOG]   Module helper loaded: newsfeed
                                  [26.03.2021 11:17.39.867] [LOG]   init module helper undefinedundefined
                                  [26.03.2021 11:17.39.868] [LOG]   Module helper loaded: uploadPics
                                    @innovation if u do the > symbol, then ALL the output goes to the file
                                    • I
                                      @sdetweil > magicmirror@2.13.0 start /home/pi/MagicMirror
                                      [2021-03-26 22:24:56.461] [LOG] Starting MagicMirror: v2.13.0
                                      [2021-03-26 22:24:56.519] [LOG] Loading config …
                                      [2021-03-26 22:24:56.541] [LOG] Loading module helpers …
                                      [2021-03-26 22:24:56.546] [LOG] No helper found for module: compliments.
                                      [2021-03-26 22:24:56.556] [LOG] No helper found for module: MMM-CSSBackgrounds.
                                      [2021-03-26 22:24:56.586] [LOG] Module helper loaded: uploadPics
                                      [2021-03-26 22:24:56.588] [LOG] All module helpers loaded.
                                      [2021-03-26 22:24:57.103] [LOG] Starting server on port 8080 …
                                      [2021-03-26 22:24:57.164] [LOG] Server started …
                                      [2021-03-26 22:24:57.166] [LOG] Connecting socket for: uploadPics
                                      [2021-03-26 22:24:57.168] [LOG] Sockets connected & modules started …
                                      [2021-03-26 22:24:58.047] [LOG] Launching application.
                                      ^C[2021-03-26 22:26:14.188] [LOG] Shutting down server…
                                        @innovation did u add debug: true to the uploadPics module config section
        module:"uploadPics",
        disabled:false,
        position:"bottom_left",
        config:{
        dest : '../modules/MMM-ImagesPhotos/uploads',
        debug:true
                                        • I
                                          @sdetweil Sorry, put it in the wrong place
                                          [2021-03-26 22:34:16.943] [LOG] Starting MagicMirror: v2.13.0
                                          [2021-03-26 22:34:17.001] [LOG] Loading config …
                                          [2021-03-26 22:34:17.016] [LOG] Loading module helpers …
                                          [2021-03-26 22:34:17.020] [LOG] No helper found for module: compliments.
                                          [2021-03-26 22:34:17.026] [LOG] No helper found for module: MMM-CSSBackgrounds.
                                          [2021-03-26 22:34:17.045] [LOG] Module helper loaded: uploadPics
                                          [2021-03-26 22:34:17.046] [LOG] All module helpers loaded.
                                          [2021-03-26 22:34:17.520] [LOG] Starting server on port 8080 …
                                          [2021-03-26 22:34:17.560] [LOG] Server started …
                                          [2021-03-26 22:34:17.562] [LOG] Connecting socket for: uploadPics
                                          [2021-03-26 22:34:17.564] [LOG] Sockets connected & modules started …
                                          [2021-03-26 22:34:18.464] [LOG] Launching application.
                                          [2021-03-26 22:34:24.895] [LOG] uploadPics received a socket notification: CONFIG - Payload: [object Object]
                                          [2021-03-26 22:34:24.898] [LOG] p=/home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads
                                          [2021-03-26 22:34:26.239] [LOG] error=Error: stat /home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads: no such file or directory
                                          Run qrcp help for help.
                                          ^C[2021-03-26 22:34:38.105] [LOG] Shutting down server…
                                          [2021-03-26 22:34:38.107] [LOG] Stopping module helper: uploadPics
                                            @innovation said in Help please!!:
                                            where are the uploaded pics supposed to go?
                                            that folder doesn’t exist…
                                            • 3 / 4
