    Help please!!
    63 Posts 4 Posters 38.8k Views 4 Watching
      sdetweil @innovation
      @innovation ok, start mm
      I 1 Reply Last reply
      • I
        innovation @sdetweil
        @sdetweil I am getting the same “default message if none supplied in the config.js”
          @innovation weird
          ok, add
          debug: true,
          to the module definition
          and then do
          npm start >somefile
          once mm comes up u can stop it and then we can look at somefile
          • I
            @sdetweil npm start >somefile
            npm ERR! missing script: start
            npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
            Yes, the program started then I ended it
              @innovation from the magicmirror folder please
              • I
                @sdetweil Yes it opened. Where is the somefile?
                  @innovation in the magicmirror folder
                  > means put all the terminal window content of the pgm into the file
                  (same as for windows)
                  • I
                    @sdetweil Nothing shows up in the terminal when I run in though
                    S 2 Replies Last reply
                      @innovation don’t understand, mm puts out messages
                      looks like this
                      > magicmirror@2.14.0 start /home/sam/MagicMirror
                      [26.03.2021 11:17.39.334] [LOG]   Starting MagicMirror: v2.14.0
                      [26.03.2021 11:17.39.338] [LOG]   Loading config ...
                      [26.03.2021 11:17.39.343] [LOG]   Loading module helpers ...
                      [26.03.2021 11:17.39.345] [LOG]   No helper found for module: alert.
                      [26.03.2021 11:17.39.483] [LOG]   Initializing new module helper ...
                      [26.03.2021 11:17.39.483] [LOG]   Module helper loaded: updatenotification
                      [26.03.2021 11:17.39.484] [LOG]   No helper found for module: clock.
                      [26.03.2021 11:17.39.843] [LOG]   Initializing new module helper ...
                      [26.03.2021 11:17.39.843] [LOG]   Module helper loaded: calendar
                      [26.03.2021 11:17.39.844] [LOG]   No helper found for module: currentweather.
                      [26.03.2021 11:17.39.845] [LOG]   No helper found for module: weatherforecast.
                      [26.03.2021 11:17.39.865] [LOG]   Initializing new module helper ...
                      [26.03.2021 11:17.39.866] [LOG]   Module helper loaded: newsfeed
                      [26.03.2021 11:17.39.867] [LOG]   init module helper undefinedundefined
                      [26.03.2021 11:17.39.868] [LOG]   Module helper loaded: uploadPics
                        @innovation if u do the > symbol, then ALL the output goes to the file
                        • I
                          @sdetweil > magicmirror@2.13.0 start /home/pi/MagicMirror
                          [2021-03-26 22:24:56.461] [LOG] Starting MagicMirror: v2.13.0
                          [2021-03-26 22:24:56.519] [LOG] Loading config …
                          [2021-03-26 22:24:56.541] [LOG] Loading module helpers …
                          [2021-03-26 22:24:56.546] [LOG] No helper found for module: compliments.
                          [2021-03-26 22:24:56.556] [LOG] No helper found for module: MMM-CSSBackgrounds.
                          [2021-03-26 22:24:56.586] [LOG] Module helper loaded: uploadPics
                          [2021-03-26 22:24:56.588] [LOG] All module helpers loaded.
                          [2021-03-26 22:24:57.103] [LOG] Starting server on port 8080 …
                          [2021-03-26 22:24:57.164] [LOG] Server started …
                          [2021-03-26 22:24:57.166] [LOG] Connecting socket for: uploadPics
                          [2021-03-26 22:24:57.168] [LOG] Sockets connected & modules started …
                          [2021-03-26 22:24:58.047] [LOG] Launching application.
                          ^C[2021-03-26 22:26:14.188] [LOG] Shutting down server…
                            @innovation did u add debug: true to the uploadPics module config section
                                                    module:"uploadPics",
                                                    disabled:false,
                                                    position:"bottom_left",
                                                    config:{
                                                            dest : '../modules/MMM-ImagesPhotos/uploads',
                                                            debug:true
                            • I
                              @sdetweil Sorry, put it in the wrong place
                              [2021-03-26 22:34:16.943] [LOG] Starting MagicMirror: v2.13.0
                              [2021-03-26 22:34:17.001] [LOG] Loading config …
                              [2021-03-26 22:34:17.016] [LOG] Loading module helpers …
                              [2021-03-26 22:34:17.020] [LOG] No helper found for module: compliments.
                              [2021-03-26 22:34:17.026] [LOG] No helper found for module: MMM-CSSBackgrounds.
                              [2021-03-26 22:34:17.045] [LOG] Module helper loaded: uploadPics
                              [2021-03-26 22:34:17.046] [LOG] All module helpers loaded.
                              [2021-03-26 22:34:17.520] [LOG] Starting server on port 8080 …
                              [2021-03-26 22:34:17.560] [LOG] Server started …
                              [2021-03-26 22:34:17.562] [LOG] Connecting socket for: uploadPics
                              [2021-03-26 22:34:17.564] [LOG] Sockets connected & modules started …
                              [2021-03-26 22:34:18.464] [LOG] Launching application.
                              [2021-03-26 22:34:24.895] [LOG] uploadPics received a socket notification: CONFIG - Payload: [object Object]
                              [2021-03-26 22:34:24.898] [LOG] p=/home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads
                              [2021-03-26 22:34:26.239] [LOG] error=Error: stat /home/pi/MagicMirror/modules/MMMM-ImagesPhotos/uploads: no such file or directory
                              Run qrcp help for help.
                              ^C[2021-03-26 22:34:38.105] [LOG] Shutting down server…
                              [2021-03-26 22:34:38.107] [LOG] Stopping module helper: uploadPics
                                @innovation said in Help please!!:
                                where are the uploaded pics supposed to go?
                                that folder doesn’t exist…
                                • I
                                  @sdetweil But there is a folder in
                                  /home/pi/MagicMirror/modules/MMM-ImagesPhotos/uploads
                                    @innovation ‘’/MMMM’
                                    typo in the dest config… 4 M’s instead of 3
                                    • I
                                      @sdetweil Yes it works! Thank you so much for this. I really appreciate it
                                        @innovation glad u got it… i changed the message to say check the config
                                        and also allowed the error message to pass thru even if not in debug mode… thanks for your patience
                                        • 3 / 4
