    Help please!!
    63 Posts 4 Posters 34.8k Views 4 Watching
      sdetweil @innovation
      @innovation yes
      • I Offline
        innovation @sdetweil
        @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
        These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
        Use man -k' or info’ to find out more about commands not in this list.
        A star (*) next to a name means that the command is disabled.
        job_spec [&] history [-c] [-d offset] [n] or history -anrw >
        (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
        . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
        : kill [-s sigspec | -n signum | -sigspec] pid |>
        [ arg… ] let arg [arg …]
        [[ expression ]] local [option] name[=value] …
        alias [-p] [name[=value] … ] logout [n]
        bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
        bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
        break [n] printf [-v var] format [arguments]
        builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
        caller [expr] pwd [-LP]
        case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
        cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
        command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
        compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
        complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
        compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
        continue [n] shift [n]
        coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
        declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
        dirs [-clpv] [+N] [-N] suspend [-f]
        disown [-h] [-ar] [jobspec … | pid …] test [expr]
        echo [-neE] [arg …] time [-p] pipeline
        enable [-a] [-dnps] [-f filename] [name …] times
        eval [arg …] trap [-lp] [[arg] signal_spec …]
        exec [-cl] [-a name] [command [arguments …]] > true
        exit [n] type [-afptP] name [name …]
        export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
        false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
        fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
        fg [job_spec] unalias [-a] name [name …]
        for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
        for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
        function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
        getopts optstring name [arg] wait [-fn] [id …]
        hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
        help [-dms] [pattern …] { COMMANDS ; }
        This is what it says
          @innovation what did u type??
          qrcp
          should have replied
          sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
          Error: requires at least 1 arg(s), only received 0
          Run `qrcp help` for help.
          anf then, if the file was present
          ls qrcp.json
          should have replied
          sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
          qrcp.json
          • I Offline
            pi@smart:~ $ qrcp
            Run qrcp help for help.
              @innovation and for the file?
              • I Offline
                pi@smart:~ $ ls qrcp.json
                ls: cannot access ‘qrcp.json’: No such file or directory
                pi@smart:~ $
                  @innovation ok, then do these two commands
                  ip link show
                  iwconfig
                  show the results
                  mine look like this
                  sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
                  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
                      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                  9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
                      link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
                  sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
                  wlp1s0    IEEE 802.11  ESSID:"fubar"
                            Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                            Bit Rate=650 Mb/s   Tx-Power=22 dBm
                            Retry short limit:7   RTS thr:off   Fragment thr:off
                            Power Management:on
                            Link Quality=70/70  Signal level=-34 dBm
                            Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                            Tx excessive retries:0  Invalid misc:52   Missed beacon:0
                  lo        no wireless extensions.
                  I 2 Replies Last reply Reply Quote 0
                  • I Offline
                    • I Offline
                      pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
                      2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
                      link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
                      3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
                      link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
                      pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
                      eth0 no wireless extensions.
                      wlan0 IEEE 802.11 ESSID:“ssk3”
                      Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
                      Bit Rate=24 Mb/s Tx-Power=31 dBm
                      Power Management:on
                      Link Quality=42/70 Signal level=-68 dBm
                      Tx excessive retries:10 Invalid misc:0 Missed beacon:0
                        @innovation ok,
                        postinstall should be 43 lines long
                        if so do this
                        ./postinstall
                        the check for qrcp.json again
                        • I Offline
                          @sdetweil Yes the file is there now
                          pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                          qrcp.json
                            @innovation ok, start mm
                            • I Offline
                              @sdetweil I am getting the same “default message if none supplied in the config.js”
                                @innovation weird
                                ok, add
                                debug: true,
                                to the module definition
                                and then do
                                npm start >somefile
                                once mm comes up u can stop it and then we can look at somefile
                                • I Offline
                                  @sdetweil npm start >somefile
                                  npm ERR! missing script: start
                                  npm ERR! /home/pi/.npm/_logs/2021-03-26T16_26_09_848Z-debug.log
                                  Yes, the program started then I ended it
                                    @innovation from the magicmirror folder please
                                    • I Offline
                                      @sdetweil Yes it opened. Where is the somefile?
                                        @innovation in the magicmirror folder
                                        > means put all the terminal window content of the pgm into the file
                                        (same as for windows)
                                        • I Offline
                                          @sdetweil Nothing shows up in the terminal when I run in though
                                            @innovation don’t understand, mm puts out messages
                                            looks like this
                                            > magicmirror@2.14.0 start /home/sam/MagicMirror
                                            [26.03.2021 11:17.39.334] [LOG]   Starting MagicMirror: v2.14.0
                                            [26.03.2021 11:17.39.338] [LOG]   Loading config ...
                                            [26.03.2021 11:17.39.343] [LOG]   Loading module helpers ...
                                            [26.03.2021 11:17.39.345] [LOG]   No helper found for module: alert.
                                            [26.03.2021 11:17.39.483] [LOG]   Initializing new module helper ...
                                            [26.03.2021 11:17.39.483] [LOG]   Module helper loaded: updatenotification
                                            [26.03.2021 11:17.39.484] [LOG]   No helper found for module: clock.
                                            [26.03.2021 11:17.39.843] [LOG]   Initializing new module helper ...
                                            [26.03.2021 11:17.39.843] [LOG]   Module helper loaded: calendar
                                            [26.03.2021 11:17.39.844] [LOG]   No helper found for module: currentweather.
                                            [26.03.2021 11:17.39.845] [LOG]   No helper found for module: weatherforecast.
                                            [26.03.2021 11:17.39.865] [LOG]   Initializing new module helper ...
                                            [26.03.2021 11:17.39.866] [LOG]   Module helper loaded: newsfeed
                                            [26.03.2021 11:17.39.867] [LOG]   init module helper undefinedundefined
                                            [26.03.2021 11:17.39.868] [LOG]   Module helper loaded: uploadPics
                                            • 3 / 4
