    Help please!!
    63 Posts 4 Posters 38.6k Views 4 Watching
      sdetweil @innovation
      @innovation did you git pull and npm install the latest
      the postinstall script is supposed to fix that
      • I
        innovation @sdetweil
        It says it’s up to date
          @innovation and then u did npm install
          • I
            innovation
            @sdetweil Yes
              @innovation can u open a terminal window and do
              qrcp
              and look in the module folder for qrcp.json
              • I
                @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                  @innovation yes
                  • I
                    @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
                    These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
                    Use man -k' or info’ to find out more about commands not in this list.
                    A star (*) next to a name means that the command is disabled.
                    job_spec [&] history [-c] [-d offset] [n] or history -anrw >
                    (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
                    . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
                    : kill [-s sigspec | -n signum | -sigspec] pid |>
                    [ arg… ] let arg [arg …]
                    [[ expression ]] local [option] name[=value] …
                    alias [-p] [name[=value] … ] logout [n]
                    bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
                    bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
                    break [n] printf [-v var] format [arguments]
                    builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
                    caller [expr] pwd [-LP]
                    case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
                    cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
                    command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
                    compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
                    complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
                    compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
                    continue [n] shift [n]
                    coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
                    declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
                    dirs [-clpv] [+N] [-N] suspend [-f]
                    disown [-h] [-ar] [jobspec … | pid …] test [expr]
                    echo [-neE] [arg …] time [-p] pipeline
                    enable [-a] [-dnps] [-f filename] [name …] times
                    eval [arg …] trap [-lp] [[arg] signal_spec …]
                    exec [-cl] [-a name] [command [arguments …]] > true
                    exit [n] type [-afptP] name [name …]
                    export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
                    false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
                    fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
                    fg [job_spec] unalias [-a] name [name …]
                    for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
                    for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
                    function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
                    getopts optstring name [arg] wait [-fn] [id …]
                    hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
                    help [-dms] [pattern …] { COMMANDS ; }
                    This is what it says
                      @innovation what did u type??
                      qrcp
                      should have replied
                      sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
                      Error: requires at least 1 arg(s), only received 0
                      Run `qrcp help` for help.
                      anf then, if the file was present
                      ls qrcp.json
                      should have replied
                      sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
                      qrcp.json
                      • I
                        pi@smart:~ $ qrcp
                        Run qrcp help for help.
                          @innovation and for the file?
                          • I
                            pi@smart:~ $ ls qrcp.json
                            ls: cannot access ‘qrcp.json’: No such file or directory
                            pi@smart:~ $
                              @innovation ok, then do these two commands
                              ip link show
                              iwconfig
                              show the results
                              mine look like this
                              sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
                              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
                                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                              9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
                                  link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
                              sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
                              wlp1s0    IEEE 802.11  ESSID:"fubar"
                                        Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                                        Bit Rate=650 Mb/s   Tx-Power=22 dBm
                                        Retry short limit:7   RTS thr:off   Fragment thr:off
                                        Power Management:on
                                        Link Quality=70/70  Signal level=-34 dBm
                                        Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                                        Tx excessive retries:0  Invalid misc:52   Missed beacon:0
                              lo        no wireless extensions.
                              I 2 Replies Last reply Reply Quote 0
                              • I
                                • I
                                  pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
                                  2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
                                  link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
                                  3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
                                  link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
                                  pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
                                  eth0 no wireless extensions.
                                  wlan0 IEEE 802.11 ESSID:“ssk3”
                                  Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
                                  Bit Rate=24 Mb/s Tx-Power=31 dBm
                                  Power Management:on
                                  Link Quality=42/70 Signal level=-68 dBm
                                  Tx excessive retries:10 Invalid misc:0 Missed beacon:0
                                    @innovation ok,
                                    postinstall should be 43 lines long
                                    if so do this
                                    ./postinstall
                                    the check for qrcp.json again
                                    • I
                                      @sdetweil Yes the file is there now
                                      pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                                      qrcp.json
                                        @innovation ok, start mm
                                        • I
                                          @sdetweil I am getting the same “default message if none supplied in the config.js”
                                            @innovation weird
                                            ok, add
                                            debug: true,
                                            to the module definition
                                            and then do
                                            npm start >somefile
                                            once mm comes up u can stop it and then we can look at somefile
                                            • 2 / 4
