    Help please!!
    63 Posts 4 Posters 36.2k Views 4 Watching
    • I Offline
      innovation @sdetweil
      @sdetweil Hello! Yes I can see the QR code on the display. However, when I scan it - this is what its showing me
      What does this mean?
        sdetweil @innovation
        @innovation did you git pull and npm install the latest
        the postinstall script is supposed to fix that
        • I Offline
          It says it’s up to date
            @innovation and then u did npm install
            • I Offline
              innovation
              @sdetweil Yes
                @innovation can u open a terminal window and do
                qrcp
                and look in the module folder for qrcp.json
                • I Offline
                  @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                    @innovation yes
                    • I Offline
                      @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
                      These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
                      Use man -k' or info’ to find out more about commands not in this list.
                      A star (*) next to a name means that the command is disabled.
                      job_spec [&] history [-c] [-d offset] [n] or history -anrw >
                      (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
                      . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
                      : kill [-s sigspec | -n signum | -sigspec] pid |>
                      [ arg… ] let arg [arg …]
                      [[ expression ]] local [option] name[=value] …
                      alias [-p] [name[=value] … ] logout [n]
                      bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
                      bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
                      break [n] printf [-v var] format [arguments]
                      builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
                      caller [expr] pwd [-LP]
                      case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
                      cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
                      command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
                      compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
                      complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
                      compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
                      continue [n] shift [n]
                      coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
                      declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
                      dirs [-clpv] [+N] [-N] suspend [-f]
                      disown [-h] [-ar] [jobspec … | pid …] test [expr]
                      echo [-neE] [arg …] time [-p] pipeline
                      enable [-a] [-dnps] [-f filename] [name …] times
                      eval [arg …] trap [-lp] [[arg] signal_spec …]
                      exec [-cl] [-a name] [command [arguments …]] > true
                      exit [n] type [-afptP] name [name …]
                      export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
                      false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
                      fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
                      fg [job_spec] unalias [-a] name [name …]
                      for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
                      for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
                      function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
                      getopts optstring name [arg] wait [-fn] [id …]
                      hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
                      help [-dms] [pattern …] { COMMANDS ; }
                      This is what it says
                        @innovation what did u type??
                        qrcp
                        should have replied
                        sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
                        Error: requires at least 1 arg(s), only received 0
                        Run `qrcp help` for help.
                        anf then, if the file was present
                        ls qrcp.json
                        should have replied
                        sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
                        qrcp.json
                        • I Offline
                          pi@smart:~ $ qrcp
                          Run qrcp help for help.
                            @innovation and for the file?
                            • I Offline
                              pi@smart:~ $ ls qrcp.json
                              ls: cannot access ‘qrcp.json’: No such file or directory
                              pi@smart:~ $
                                @innovation ok, then do these two commands
                                ip link show
                                iwconfig
                                show the results
                                mine look like this
                                sam@galliumos:~/MagicMirror/modules/uploadPics$ ip link show
                                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
                                    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                9: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
                                    link/ether a4:c4:94:66:7e:b1 brd ff:ff:ff:ff:ff:ff
                                sam@galliumos:~/MagicMirror/modules/uploadPics$ iwconfig
                                wlp1s0    IEEE 802.11  ESSID:"fubar"
                                          Mode:Managed  Frequency:5.745 GHz  Access Point: 24:05:88:41:B5:08
                                          Bit Rate=650 Mb/s   Tx-Power=22 dBm
                                          Retry short limit:7   RTS thr:off   Fragment thr:off
                                          Power Management:on
                                          Link Quality=70/70  Signal level=-34 dBm
                                          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
                                          Tx excessive retries:0  Invalid misc:52   Missed beacon:0
                                lo        no wireless extensions.
                                I 2 Replies Last reply Reply Quote 0
                                • I Offline
                                  • I Offline
                                    pi@smart:~/MagicMirror/modules/uploadPics $ ip link show
                                    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
                                    link/ether b8:27:eb:9b:20:c3 brd ff:ff:ff:ff:ff:ff
                                    3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
                                    link/ether b8:27:eb:ce:75:96 brd ff:ff:ff:ff:ff:ff
                                    pi@smart:~/MagicMirror/modules/uploadPics $ iwconfig
                                    eth0 no wireless extensions.
                                    wlan0 IEEE 802.11 ESSID:“ssk3”
                                    Mode:Managed Frequency:2.422 GHz Access Point: CC:32:E5:E9:02:27
                                    Bit Rate=24 Mb/s Tx-Power=31 dBm
                                    Power Management:on
                                    Link Quality=42/70 Signal level=-68 dBm
                                    Tx excessive retries:10 Invalid misc:0 Missed beacon:0
                                      @innovation ok,
                                      postinstall should be 43 lines long
                                      if so do this
                                      ./postinstall
                                      the check for qrcp.json again
                                      • I Offline
                                        @sdetweil Yes the file is there now
                                        pi@smart:~/MagicMirror/modules/uploadPics $ ls qrcp.json
                                        qrcp.json
                                          @innovation ok, start mm
                                          • I Offline
                                            @sdetweil I am getting the same “default message if none supplied in the config.js”
                                            • 2 / 4
