    Help please!!
    63 Posts 4 Posters 38.8k Views 4 Watching
      sdetweil @innovation
      @innovation but the module wants RELATIVE to it… NOT absolute
      SO, …/MMM-ImagesPhotos/upload
      … means back up one level
      and, if you are using the MMM-ImagesPhotos module to display images, then the uploadPics dest: default is …/MMM-ImagesPhotos/upload
      from the readme
      	dest:  "..", // relative path to module showing images, place to put new images
                  // for MMM-ImagesPhotos dest is (the default)
      	//  ../modules/MMMM-ImagesPhotos/uploads
      I 1 Reply Last reply
      • I
        innovation @sdetweil
        @sdetweil Yes, it still is showing undefined though
          @innovation
          is this on a pi4? I see a problem with the qrcp it wants to know which adapter to run on, wifi or ethernet… and its parms aren;t working… I tried on all kinds of machines with one adapter… weird…
          if pi4 open terminal do qrcp config
          and basically hit enter til it ends
          then try mm again
          S I 2 Replies Last reply
            install setup fixed
            please git pull
            and then npm install again
            B 1 Reply Last reply
            • I
              @sdetweil No, it is a Pi 3B
                barlouka @sdetweil
                @sdetweil Thank you. It works perfect. Fantastic module.
                  I added some more updates, the app that corrects the image orientation runs only on what u upload now, not ALL the images int he folder… (could be hundreds or thousands)…
                  debug:true to turn on messages from node helper and module (false by default)
                  took out other dead code
                  edit: to add the npm install
                  git pull in the module folder to get the latest, npm install and then restart MM
                  • I
                    • I
                      @sdetweil Hello! Yes I can see the QR code on the display. However, when I scan it - this is what its showing me
                      What does this mean?
                        @innovation did you git pull and npm install the latest
                        the postinstall script is supposed to fix that
                        • I
                          It says it’s up to date
                            @innovation and then u did npm install
                            • I
                              innovation
                              @sdetweil Yes
                                @innovation can u open a terminal window and do
                                qrcp
                                and look in the module folder for qrcp.json
                                • I
                                  @sdetweil Into cd ~/MagicMirror/modules/uploadPics?
                                    @innovation yes
                                    • I
                                      @sdetweil GNU bash, version 5.0.3(1)-release (arm-unknown-linux-gnueabihf)
                                      These shell commands are defined internally. Type help' to see this list. Type help name’ to find out more about the function name'. Use info bash’ to find out more about the shell in general.
                                      Use man -k' or info’ to find out more about commands not in this list.
                                      A star (*) next to a name means that the command is disabled.
                                      job_spec [&] history [-c] [-d offset] [n] or history -anrw >
                                      (( expression )) if COMMANDS; then COMMANDS; [ elif COMMANDS; t>
                                      . filename [arguments] jobs [-lnprs] [jobspec …] or jobs -x command>
                                      : kill [-s sigspec | -n signum | -sigspec] pid |>
                                      [ arg… ] let arg [arg …]
                                      [[ expression ]] local [option] name[=value] …
                                      alias [-p] [name[=value] … ] logout [n]
                                      bg [job_spec …] mapfile [-d delim] [-n count] [-O origin] [-s >
                                      bind [-lpsvPSVX] [-m keymap] [-f filename] [-q > popd [-n] [+N | -N]
                                      break [n] printf [-v var] format [arguments]
                                      builtin [shell-builtin [arg …]] pushd [-n] [+N | -N | dir]
                                      caller [expr] pwd [-LP]
                                      case WORD in [PATTERN [| PATTERN]…) COMMANDS > read [-ers] [-a array] [-d delim] [-i text] [->
                                      cd [-L|[-P [-e]] [-@]] [dir] readarray [-d delim] [-n count] [-O origin] [->
                                      command [-pVv] command [arg …] readonly [-aAf] [name[=value] …] or readonly>
                                      compgen [-abcdefgjksuv] [-o option] [-A action]> return [n]
                                      complete [-abcdefgjksuv] [-pr] [-DEI] [-o optio> select NAME [in WORDS … ;] do COMMANDS; done
                                      compopt [-o|+o option] [-DEI] [name …] set [-abefhkmnptuvxBCHP] [-o option-name] [–]>
                                      continue [n] shift [n]
                                      coproc [NAME] command [redirections] shopt [-pqsu] [-o] [optname …]
                                      declare [-aAfFgilnrtux] [-p] [name[=value] …> source filename [arguments]
                                      dirs [-clpv] [+N] [-N] suspend [-f]
                                      disown [-h] [-ar] [jobspec … | pid …] test [expr]
                                      echo [-neE] [arg …] time [-p] pipeline
                                      enable [-a] [-dnps] [-f filename] [name …] times
                                      eval [arg …] trap [-lp] [[arg] signal_spec …]
                                      exec [-cl] [-a name] [command [arguments …]] > true
                                      exit [n] type [-afptP] name [name …]
                                      export [-fn] [name[=value] …] or export -p typeset [-aAfFgilnrtux] [-p] name[=value] …
                                      false ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
                                      fc [-e ename] [-lnr] [first] [last] or fc -s [p> umask [-p] [-S] [mode]
                                      fg [job_spec] unalias [-a] name [name …]
                                      for NAME [in WORDS … ] ; do COMMANDS; done unset [-f] [-v] [-n] [name …]
                                      for (( exp1; exp2; exp3 )); do COMMANDS; done until COMMANDS; do COMMANDS; done
                                      function name { COMMANDS ; } or name () { COMMA> variables - Names and meanings of some shell v>
                                      getopts optstring name [arg] wait [-fn] [id …]
                                      hash [-lr] [-p pathname] [-dt] [name …] while COMMANDS; do COMMANDS; done
                                      help [-dms] [pattern …] { COMMANDS ; }
                                      This is what it says
                                        @innovation what did u type??
                                        qrcp
                                        should have replied
                                        sam@galliumos:~/MagicMirror/modules/uploadPics$ qrcp
                                        Error: requires at least 1 arg(s), only received 0
                                        Run `qrcp help` for help.
                                        anf then, if the file was present
                                        ls qrcp.json
                                        should have replied
                                        sam@galliumos:~/MagicMirror/modules/uploadPics$ ls qrcp.json
                                        qrcp.json
                                        • I
                                          pi@smart:~ $ qrcp
                                          Run qrcp help for help.
                                            @innovation and for the file?
                                            • 2 / 4
