    problems with starting
    2 Posts 2 Posters 431 Views 2 Watching
    • K Offline
      Karalica-Kir
      0|mm  | Whoops! There was an uncaught exception...
      0|mm  | [2021-03-26 12:14:51.687] [ERROR]
      0|mm  | SyntaxError: Unexpected end of JSON input
      0|mm  |     at JSON.parse (<anonymous>)
      0|mm  |     at Class.getStyleMap (/home/pi/MagicMirror/modules/MMM-GoogleMapsTraffic/node_helper.js:37:46)
      0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-GoogleMapsTraffic/node_helper.js:22:52)
      0|mm  |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
      0|mm  |     at Socket.emit (events.js:200:13)
      0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:82:9)
      • lavolp3L Offline
        lavolp3 Module Developer @Karalica-Kir
        @karalica-kir
        A bit more explanation around all this would be helpful.
        You have an issue with the mentioned module MMM-GoogleMapsTraffic.
        It wants to read a json input that it cannot understand.
        MOst probably from the Google maps API.
        SO I would assume somethings wrong with your api key for the google maps api.
        But I can only guess.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
