    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.1k Views 35 Watching
    • lavolp3L
      lavolp3 Module Developer @0m4r
      @0m4r said in MMM-SoccerLiveScore:
      yes, the score is provided.
      If the game is ended it provides the final result, if the game is on-going you get the current score, if the game is not started it provides a default “0 - 0” result.
      Thanks but i meant the information about the goals: minutes, scorers
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      0m4r0 1 Reply Last reply
      • 0m4r0
        0m4r Module Developer @lavolp3
        @lavolp3 I think with some more work it can be done…
        I am also considering to add the scorers standings for each league
        It is quite a hard work to reverse engineer the APIs, but it is fun :D
        https://github.com/0m4r
        lavolp3L 1 Reply Last reply
        • lavolp3L
          @0m4r Well I don’t know anything about reverse engineering so appreciate if you find anything.
          E 1 Reply Last reply
          • E
            Egnos @lavolp3
            Hi guys,
            for a couple of days I have not seen the results of Serie A (Italy) and Champions League.
            Is it just me who has this problem?
            Thank you.
            • 0m4r0
              0m4r Module Developer @Egnos
              @egnos I can still see them, but I have installed my own fork which I tweaked and fixed in some places: https://github.com/0m4r/MMM-SoccerLiveScore
              If you are familiar with github you can even try some of the new features I am working on by checking out the developer branch :)
              • E
                Egnos @0m4r
                @0m4r thanks for answering me.
                Now it works without my intervention!
                Where can I find the news you are working on?
                0m4r0 S 2 Replies Last reply
                • 0m4r0
                  @egnos I posted the link to the repo in my prev comment.
                  Anyhow, to see the latest (under development) updates, after you cloe you need to switch to the development branch:
                  from your MagicMirror home folder, enter the modules one
                  cd modules
                  clone the repo
                  git clone https://github.com/0m4r/MMM-SoccerLiveScore
                  checkout the development branch
                  git checkout development
                  You may need to restart MagicMirror.
                    schlittrix @Egnos
                    @egnos said in MMM-SoccerLiveScore:
                    Thanks, module works fine.
                    One question: I just set the standings without table and without text. I would like to show it in die top_bar.
                    config:
                    	module: 'MMM-SoccerLiveScore',
                    	position: 'top_left',
                    	header: 'Live-Scores',
                    		leagues: [35],
                            showNames: false,
                            showLogos: true,
                            displayTime: 60 * 1000,
                            showTables: false
                    my problem is, the weidth is over the whole monitor (standings in the middle, but the logos on the maximum left and maximum right side. so the other modules are too far down. Is it possible to set the module with a fix width f.e. 400px?
                    • 0m4r0
                      0m4r Module Developer @schlittrix
                      uhm… the problem is that you may not be able to see the whole standings then.
                      I have also go got a similar problem and still have not found a real solution.
                      Ayway, you can try to add in the custom.css something like:
                      .module.MMM-SoccerLiveScore {
                          max-height: 400px; //any value that fits you
                          overflow: hidden;
                        schlittrix @0m4r
                            overflow: hidden;
                        Hm. Tried it without success.
                        But i dont understand. Between 0:0 and the logos is so much space… and on the top, there is an underline filling the whole width… in the Screenshot from this Module, the logos were still between the results…
                        • 0m4r0
                          @schlittrix I have done some changes and have not updated the screenshots :P
                          I may need to review the layout with only the logos “on”.
                          … btw, I realized, I gave you the wrong piece of code, that one would fix the height, but you asked for the width, can you try like this:
                              max-width: 400px; //any value that fits you
                              overflow: hidden;
                            schlittrix @0m4r
                                overflow: hidden;
                            aaah okay :D
                            yeah, I realized the height-width mix, but also tried it with width… no success :(
                            • 0m4r0
                              @schlittrix I just tried this:
                                max-width: 400px;
                                overflow: hidden;
                                background-color: red; // debug only
                              and it seems to work
                              • 0m4r0
                                0m4r Module Developer @0m4r
                                I have just released a new version on the master branch of my own fork of this module, it is available here: https://github.com/0m4r/MMM-SoccerLiveScore.
                                There are a lot of code cleanups, refactoring, and improvements.
                                There are also a few new features:
                                • enable the display of the “scorers” for the leagues.
                                • tables display a red pulsating dot on the game that are “live” at that moment in time
                                • is it possible to only display one of the standings, tables, and scorers
                                • headers display more information about (league name and round!)
                                • table got faded colors to indicate relevant positions
                                As a plus, as it was reported to me already before, the logo of Juventus is not visible! (@Egnos this is for you!)
                                https://raw.githubusercontent.com/0m4r/MMM-SoccerLiveScore/master/MMM-SoccerLiveScores-Scorers.png
                                https://raw.githubusercontent.com/0m4r/MMM-SoccerLiveScore/master/MMM-SoccerLiveScores-Tables.png
                                https://raw.githubusercontent.com/0m4r/MMM-SoccerLiveScore/master/MMM-SoccerLiveScores-Standings.png
                                • 0m4r0
                                  @egnos this should be fixed with the last release, see https://forum.magicmirror.builders/topic/1169/mmm-soccerlivescore/103?_=1617689765014
                                  • lavolp3L
                                    @0m4r YOur module is looking better and better. Have you had the cahnce to look for more details about game scores.
                                    I’m looking for something like
                                                Manchester City     2 - 1    Dortmund
                                                 1:0 De Bruyne 19' 1:1 Reus 84'
                                                 2:1 Foden 90'
                                    to show on first sight.
                                    • 0m4r0
                                      @lavolp3 yes, I have had a look into it and it is in the making. I do not get to have much time to work on this side project, so you may need to wait a little longer for it to happen.
                                      I’ll let you know if I have a development version to show.
                                      …and thanks for the compliments! ;)
                                      • lavolp3L
                                        @0m4r Happy to help out with the development if you can provide the raw data from the API.
                                        Cheers!
                                          Sceetch
                                          Hi together,
                                          im using this wonderful module to display the live scores + standing. It works really good.
                                          I noticed that the standings of LaLiga (Spain) and Serie A (Italia) are not displayed.
                                          Is there any way to fix it.? Does anybody know this issue?
                                          Where does the module get the data from?
                                          Thx in advance.
                                          • 0m4r0
                                            0m4r Module Developer @Sceetch
                                            @sceetch weird, it works god for me… can you show me your configuration for the module?
                                            • 10
                                            • 5 / 10
