    MM-Navbar - Navigation Bar for Touchscreens to hide/show modules
    47 Posts 11 Posters 46.4k Views 15 Watching
    • cowboysdudeC Offline
      Pictures? :)
      • tidus5T Offline
        tidus5 @chrisyy
        @chrisyy i think you can list all the modules yes but how to attribut the good icon?
        i will check for hide the module on startup tonight - i let you know if i find something
          chrisyy
          Thanks for ur Picture. Mine is looking similar.
          Thats the next thing i thought about. U got all modules, but still u need a text file or sth with a module -> Icon categorization.
          My tries to hide all modules on startup were leading to a totally black screen.
          @tidus5 can I use the picture for github?
          tidus5T 1 Reply Last reply Reply Quote 0
          • tidus5T Offline
            tidus5 @chrisyy
            @chrisyy yes of course :-)
              cowboysdude Module Developer @tidus5
              @tidus5 VERY excellent!! Thank you… I can use that :)
                chrisyy
                i added the code to hide all modules on startup :)
                • tidus5T Offline
                  tidus5 @chrisyy
                  @chrisyy
                  pretty cool
                  im using your code
                  MM.getModules().exceptModule(this).exceptWithClass(‘clock’).enumerate(function(module){
                  module.hide(1000, function(){
                  to create an icon to hide or show all
                  for now i can only show all - cant hide all after.
                  did you plan to work on that ?
                    chrisyy
                    Its a possibility.
                    Think u are missing a toggle there, i can build u one later and update it.
                      chrisyy
                      @tidus5
                      Can u try this?
                      var hideallmodules = true;
                      var hideallmodulesbutton = document.createElement(“span”);
                      hideallmodulesbutton.className = “wi wi-day-rain-mix navbar”; // change icon here
                      wrapper.appendChild(hideallmodulesbutton);
                      $(hideallmodulesbutton).on(“click”, function(){
                      if(hideallmodules){
                      module.show(1000, function(){
                      hideallmodules = false;
                      }else{
                      this is a bit messy, but should work as the rest of the buttons. will publish it to git, when i got time.
                      • tidus5T Offline
                        tidus5 @chrisyy
                        @chrisyy Hello
                        amazing!!! thank you
                        just small error added exceptWithClass(‘MM-navbar’) (exceptmodule(this)) didnt work (the nav itself was hidden)
                        thank you so much
                        	$(hideallmodulesbutton).on("click", function(){
                        		if(hideallmodules){
                        			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('clock').enumerate(function(module){
                        		}else{
                        • 1 / 5
