Black screen without error when using MM modules
Hi all,
my rasberry pi3 magic mirror installation works fine with the standard modules.
Although, I tried to add some custom modules, namely the cool fish of the day module & the dailyXkCD one.
Cloning the most recent repo into the mirror folder works and is successfull. Also, I think there is no error in the config file as I do not get the “warning screen from Magic mirror” telling me that something must be wrong in the config.However, as soon as the application launches I only see a black screen. That happend for both models. #
At first I thought that I double placed modules on the same position on the screen but even after making sure that this is not the case I get the black screen.The console does not give any error message.
Are such problems module related or do I miss dependencies on my pi?
Thank you all so much for this awesome project & support
TebE
@TebE It sure sounds like there is an error in the
config.jsfile. If you can, copy your config file and paste it here and we’ll take a look at it. Please remember to 1) remove any API keys or passwords when you paste, and 2) use the markdown features (surround it with three back-ticks) to make your config file easier to read. -
Issues have been solved: Despite the detailed description I did not place the specific module folders in the “module” folder.
Works now.Thanks a lot - Post can be deleted.
