Static text on several lines
3 Posts 2 Posters 1.7k Views 2 Watching
  • Z Offline
    zkab
    I want a static text with several lines with the option to choose font and color for different lines.
    When I have several lines in config.js then only the last line will appear.
    How can that be done ?
    B 1 Reply Last reply Dec 10, 2016, 3:17 AM Reply Quote 0
      bhepler Module Developer @zkab
      @zkab You should be able to configure the Hello World module to display any text you need. Insert multiple
      entities, each with a named class. You can then configure the custom CSS to display each named class as you see fit.
      • Z Offline
        zkab
        Don’t have any experience of CSS - could you give me an example how I should continue … I checked the CSS documentation but it is HUGE … I guess if I could get some guidelines then I can figure it out …
