Newsfeed module behaves differently than Compliments with custom.css?
12 Posts 4 Posters 9.6k Views 5 Watching
  • V Offline
    valid8r
    I wanted to play around with font size and colors so I modified custom.css with the following code below my body statements:
    .newsfeed .medium {
    font-size: 60px;
    font-color: #99F;
    line-height: 60px;
    This worked nicely and my newsfeed now has a larger blue font.
    … but when I apply the same idea to the compliments module as below:
    .compliments .medium {
    font-size: 60px;
    font-color: #99F;
    line-height: 60px;
    I don’t get any change for the compliments module… what gives?
    S 1 Reply Last reply Dec 11, 2016, 10:33 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @valid8r
      @valid8r the compliments module is not using the medium class
      .compliments .xlarge {
          font-size: 60px;
          font-color: #99F;
          line-height: 60px;
      V 2 Replies Last reply Dec 11, 2016, 1:08 PM Reply Quote 0
      • V Offline
        valid8r @strawberry 3.141
        @strawberry-3.141 Thank you very much. This has helped me learn a bit more about css. This now points me in the direction of trying to find out where the compliments module definition is for the .xlarge class. Very helpful again.
        • V Offline
          @strawberry-3.141
          can you please confirm (for my css education), if the "wrapper.className = “thin xlarge bright” statement is where the font definitions are being set for the Compliments module as shown below? and if so, could I replace those strings with any of the css settings available?
          getDom: function() {
          var complimentText = this.randomCompliment();
          	var compliment = document.createTextNode(complimentText);
          	wrapper.className = "thin xlarge bright";
          	wrapper.appendChild(compliment);
          	return wrapper;
          • Y Offline
            yawns Moderator
            Yes and yes.
            You could of course modify the classname line and apply other classes. But I would recommend defining own css styles to override existing styles instead.
            If you modify the JavaScript file you could lose your changes if the module receives an update via github
            V 1 Reply Last reply Dec 11, 2016, 3:46 PM Reply Quote 1
            • V Offline
              valid8r @yawns
              @yawns To do so would be to update custom.css right? Would you be able to show an example of how that would work for a module such as compliments.
              • Z Offline
                zkab
                I get the bigger fonts in newsfeed but still white color … hmmm
                My custom.css looks like this
                body {
                .newsfeed .medium {
                font-size: 60px;
                font-color: #e6e600;
                line-height: 60px;
                .brightb {
                color: #a2d2f6;
                .wi-sunrise {
                color: #ff0;
                S 1 Reply Last reply Dec 12, 2016, 3:49 PM Reply Quote 0
                  strawberry 3.141 Project Sponsor Module Developer @zkab
                  @zkab did you try?
                  .newsfeed .medium {
                    font-size: 60px;
                    color: #e6e600;
                    line-height: 60px;
                  • Z Offline
                    zkab
                    Thanks - it works …
                    • Z Offline
                      zkab
                      Still struggling with fonts & colors …
                      When I insert following in custom.css I don’t get the color for calendar …
                      .calendar .small {
                      color: #a2d2f6;
                      The message Loading … is in right color but when the calendar shows it it still in white … same thing with
                      .calendar .dimmed {
                      color: #a2d2f6;
                      Where have I missed ?
