    Display monthly calendar and entries
    19 Posts 4 Posters 7.2k Views 4 Watching
      CheapDad
      @cheapdad said in Display monthly calendar and entries:
                symbol: "calendar-check",
                url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      By way of update, I’ve continued to work on this and think I’ve figured out that if I change the above URL to the one I want to populate from a website, it solves my problem. I still need to figure out how to add the second Iphone calendar and the monthly.
        sdetweil @CheapDad
        @cheapdad adding a second calendar is replicate that block
        // list of calendars
          // calendar 1
            url:...
         // calendar 2
            url:...
        ]  // end of list of calendars
        in mmm-config, just hit the plus button under calendars
        the titlereplace is an entry editing tool.
        replace the string on the left w the string in the right in the event title
        can’t help with monthly, but its a seaprate module, and will require a whole new entry in config,
        which u had in the 1st paste
        but like all other modules, look in the two logs, and check for a debug option on the module
          sdetweil @CheapDad
          @cheapdad populate from a website… yes, google is a website.
          the url needs to download an ICS file, which is what the calendar module reads to get the events
          as for calendar-monthly
          https://github.com/KirAsh4/calendar_monthly
          that one appears JUST to draw the rectangular calendar box. no actual entries
            CheapDad @sdetweil
            @sdetweil said in Display monthly calendar and entries:
            That’s interesting because I thought I had it working in a long lost iteration of my config.js. All I’m looking for is the current month’s calendar, not any entries, i.e., the 4th is a thursday, etc. Any suggestion on how to accomplish that?
              sdetweil @CheapDad
              @cheapdad u want the grid?
              then that module should do it… it has a debug mode
              its pretty simple
                CheapDad
                How do I run it in debug mode? I don’t see that on github page.
                  sdetweil @CheapDad
                  @cheapdad add
                  debugging: true
                  to the module config section
                  in mmm-config, check the box for debugging
                  sorry, used wrong word, recheck code
                    CheapDad @sdetweil
                    debug: true
                    So, I may be stuck on stupid. I enabled debug and ran MM. The monthly calendar didn’t load and I didn’t see anything different that would help me debug it.
                      sdetweil @CheapDad
                      @cheapdad sorry, notice I edited my post…
                      for this module its
                      debugging:true
                        CheapDad @sdetweil
                        @sdetweil Sorry, definitely stuck on stupid. F12 didn’t work when MM was running, but “developer tools” did. I got this from the console log:
                        Failed to load resource - 404
                        This is where the script is looking:
                        http://0.0.0.0:8080/modules/calendar-monthly/calendar-monthly.js
