    iFrame Windfinder
    21 Posts 2 Posters 7.7k Views 2 Watching
      megagprime @sdetweil
      @sdetweil i have iframe working with other things just not windfinder. Trying to add this:
      fd57ab2d-98dd-42c0-ba7d-3250e7f61f02-image.png and tried without “script source=” 39b63900-4cc7-47ce-9b2d-49c01ddf5008-image.png with single and double ", still cant finger it out :(
        sdetweil @megagprime
        @megagprime single or double, doesn’t matter, as long as both ends are the same
        url: [
              "https://www.windfinder.com/widget/forecast/js/mount_washington?
        unit_wave=ft&unit_rain=in&unit_temperature=c&unit_wind=kmh&days=4&show_day=1&show_pressure=0&show_waves=0&show_clouds=0"
          @sdetweil Hi and thanks for your help, but i tried that earlier (sorry i didnt mention) and it loads the MM but is broken iframe f29caf26-52a7-45f8-9d3f-262177674118-image.png we are missing the tail end 9072100c-183d-4261-ac72-98470d538faf-image.png
            @megagprime its the second link the does the image…
            https://www.windfinder.com/forecast/lake_pflugerville?utm_source=forecast&utm_medium=web&utm_campaign=homepageweather&utm_content=noscript-forecast
            the 1st loads some javascript to do stuff…
            this is really not a clean iframeable location…
              @sdetweil said in iFrame Windfinder:
              this is all i really want
              but would love the speeds and temps from the widget, sorter and easier to see
              Also the short link from the page you suggested does not work :(
                @megagprime yeh, they are not iframe friendly
                I wonder
                if u make another html page shell
                on your local disk, in the MM modules tree, make a new folder
                MagicMirror/modules/Windfinder
                name the file
                myembed.html (in the new folder)
                <html>
                  the embed stuff
                </html>
                then in the iframe config
                url:[ “http://localhost:MagicMirror_Port/modules/Windfinder/myembed.html”]
                  well, the embed in another file works locally, but not launched into the iframe
                  returns error
                  cannot display … in a frame because it set ‘X-Frame-Options’ to ‘SAMEORIGIN’.
                    @megagprime actually it DOES work
                    if you use the physical network for the MM address: setting
                    in my case 192.168.2.106 (not localhost or 0.0.0.0)
                    and there is a bug/… in the iframe code, need to specify height as well as width…
                    S M 2 Replies Last reply Reply Quote 1
                      @megagprime I also tried loading the extra file from the local filesystem
                      file:///home/sam/MagicMirror/modules/Windfinder/myembed.html
                      but says not allowed to load load resource.
                        @sdetweil whats your next idea? i tried htmlbox, no dice… :/
                          @megagprime I got it to work. tried a couple other things that didn’t. I’m done testing.
                            @sdetweil how? :)
                              @megagprime see the the post above that starts
                                @sdetweil just saw this! But its still not working for me :( the MM loads but does not display the iframe :( Tried with frameHeight and without f3110352-4ed5-4798-b710-c2e2272d0580-image.png
                                  @megagprime what is the
                                  address:
                                  setting up above?
                                  it MUST BE the same numeric number as in the URL
                                  cannot be localhost or 0.0.0.0 (as I said in my post)
                                    @megagprime
                                    also, if you open the developers window, ctrl-shift-i on the MM keyboard, ans select the console tab, and put part of the module name in the filter field , frame, for example here
                                    then you can see the error
                                      @sdetweil https://www.youtube.com/watch?v=1bGOgY1CmiU thanks :)
                                        @megagprime as long as it works
