    iFrame Windfinder
    21 Posts 2 Posters 7.6k Views 2 Watching
      megagprime @sdetweil
      @sdetweil said in iFrame Windfinder:
      https://www.windfinder.com/forecast/lake_pflugerville?utm_source=forecast&utm_medium=web&utm_campaign=homepageweather&utm_content=noscript-forecast
      this is all i really want
      but would love the speeds and temps from the widget, sorter and easier to see
      Also the short link from the page you suggested does not work :(
        sdetweil @megagprime
        @megagprime yeh, they are not iframe friendly
        I wonder
        if u make another html page shell
        on your local disk, in the MM modules tree, make a new folder
        MagicMirror/modules/Windfinder
        name the file
        myembed.html (in the new folder)
        <html>
          the embed stuff
        </html>
        then in the iframe config
        url:[ “http://localhost:MagicMirror_Port/modules/Windfinder/myembed.html”]
          well, the embed in another file works locally, but not launched into the iframe
          returns error
          cannot display … in a frame because it set ‘X-Frame-Options’ to ‘SAMEORIGIN’.
            @megagprime actually it DOES work
            if you use the physical network for the MM address: setting
            in my case 192.168.2.106 (not localhost or 0.0.0.0)
            and there is a bug/… in the iframe code, need to specify height as well as width…
            S M 2 Replies Last reply Reply Quote 1
              @megagprime I also tried loading the extra file from the local filesystem
              file:///home/sam/MagicMirror/modules/Windfinder/myembed.html
              but says not allowed to load load resource.
                @sdetweil whats your next idea? i tried htmlbox, no dice… :/
                  @megagprime I got it to work. tried a couple other things that didn’t. I’m done testing.
                    @sdetweil how? :)
                      @megagprime see the the post above that starts
                        @sdetweil just saw this! But its still not working for me :( the MM loads but does not display the iframe :( Tried with frameHeight and without f3110352-4ed5-4798-b710-c2e2272d0580-image.png
                          @megagprime what is the
                          address:
                          setting up above?
                          it MUST BE the same numeric number as in the URL
                          cannot be localhost or 0.0.0.0 (as I said in my post)
                            @megagprime
                            also, if you open the developers window, ctrl-shift-i on the MM keyboard, ans select the console tab, and put part of the module name in the filter field , frame, for example here
                            then you can see the error
                              @sdetweil https://www.youtube.com/watch?v=1bGOgY1CmiU thanks :)
                                @megagprime as long as it works
